Old 03-31-2023, 08:39 PM   #1
Lawson Cox
Lawson Cox's Avatar
Default Heater hose connection in head. Brass plug fitment
Long story shortened. I have a NOS brass plug, for plugging heater hose connection outlet in 60HP display engine. I have 7 heads, 2 are cast iron. I have tried to fit the plug to each head. I can only get it to go into one head, which is cast iron. I have several NOS "iron" plugs, and cannot get any of those to work either, I have run a tap into the holes on the display engine, with no better results. I would sort of like to plug these holes for appearance sake. I know threads are correct in head and on plugs.
What am I doing wrong? Suggestions.
Old 03-31-2023, 08:48 PM   #2
1952henry
1952henry's Avatar
Default Re: Heater hose connection in head. Brass plug fitment
Not to insult you in the least, you are using pipe tap? Or is this not pipe thread?
I dig coal, which provides motivation for EVs.
1952henry is offline   Reply With Quote
Old 03-31-2023, 09:13 PM   #3
Lawson Cox
Lawson Cox's Avatar
It is NOT a pipe thread. Regardless, thread in head and on plug is the same. Just having trouble getting the plug started in the head.
Old 03-31-2023, 10:11 PM   #4
Brian
Brian's Avatar
What you're doing wrong is using the wrong plugs...5/8 UNF has 18 threads per inch, 3/8 National pipe thread has 18 TPI too. So, I'm assuming that the tap you are using is 5/8 UNF and your plugs are indeed pipe thread.
Old 04-01-2023, 01:27 PM   #5
Tim Ayers
I believe Brian is right. Those holes in the head should be 3/8” pipe thread
Old 04-01-2023, 03:13 PM   #6
51504bat
51504bat's Avatar
Can't say on a V8-60 but on an 8ba they are definitely 3/8 pipe.
Old 04-01-2023, 06:35 PM   #7
Kube
Kube's Avatar
60 is pipe thread.
