03-01-2023, 05:15 PM | #1 |
Model A head gasket
What is the newest news on which gasket to use on a Snyder 5.5 to 1 Head ?
03-01-2023, 08:39 PM | #2 |
Re: Model A head gasket
Those of us in my club with HC head have been happy using the Best 509G gasket.
03-01-2023, 09:12 PM | #3 |
Snyder recommends on their web site and what I used:
Part # B-6051-XO | Model Year 28-34 DThis graphite style head gasket is basically the same gasket as our B-6051-C except it does not have the 2 small steam holes between the #2 and #3 cylinders which can be a weak point when used on a model A block. Best gasket #509G We recommend using this head gasket when running our high compression heads on a model A block. Can also be used for stock model A head applications. USA Last edited by GPierce; 03-01-2023 at 09:21 PM. |
03-03-2023, 08:29 AM | #4 |
Since 2018, I have gone through 3 head gaskets on my 190A Victoria that has a 6:1 compression ratio. The 3rd gasket, a Best 509C has been a success: · 4387 Miles: Best 509C Kevlar was installed without any sealer. Put all studs in hand tight then torqued to 30 lbs-ft, to 45 lbs-ft and then 55 lbs-ft. Next day found that gasket compressed, so re-torqued to 55 lbs-ft. 4400 Miles: Ran car 13 miles and afterward re-torqued head to 60 lbs-ft while engine was hot. Re-torqued the head again to 60 lbs-ft while the engine was hot. Some but not all nuts needed torque. 4437 Miles: Re-torqued head again to 60 lbs-ft. Gasket is still compressing. 4579 Miles: Re-torqued head to 60 lbs-ft. No issues!
Bob Bidonde Last edited by Bob Bidonde; 03-03-2023 at 08:42 AM. |
03-03-2023, 11:23 AM | #5 | |
The 1932-34 "B" style head gasket is the B-6051-C (Best 573G).
The Master Cylinder Enjoying life at the beach in SoCal... |
