Old 02-10-2023, 11:08 AM   #7
Kube
Kube's Avatar
Default Re: 59 block oil relief plunger install
Originally Posted by joel View Post
I was thinking that with the 8ba pump and it's relief valve set at 50# that there might be some kind of interaction between the two systems. If that's not an issue, ok. Thanks for replying.
Okay, NOW I believe I understand. You are replacing the oil pump with the type that has the integral relief valve. Correct?
If so, you will want to increase the spring pressure on the valve beneath the valve chamber cover. Use the ball with the flat but increase the spring pressure.
Kube is online now   Reply With Quote
