Old 02-01-2023, 12:06 PM   #13
DavidG
DavidG's Avatar
Default Re: Grease nipples.
With respect, the original tapered grease fittings do indeed have a spring-loaded ball check valve and do not leak any more than the more modern Alemite nippled fittings.
Perhaps you are thinking of the pressed-in fittings sometimes encountered in the tie rod ends. Not all of those had/still have check valves.
