Doing some work on my recently purchased 1947 Ford V8 and discovered that there are no thermostats installed in the engine. Other than effecting the temperature in the heater, is there a reason that the PO was running without thermostats?
Thank you, Phil |
If Henry Ford was here today, I bet he would say,
Don't you dare run your flathead without any thermostats ![]() ![]() .
If mama ain't happy, ain't nobody happy. But if daddy ain't happy...RUN What I GOT DONE TODAY... I got the rear-end put in the recliner, and now I'm going to rest up & watch TV.
The reason is that back in the day, a rumor got started that removing the thermostats from an engine that runs hot will solve the problem. A lot of people that should know better, don't. Old wives tales die hard.
This, and the fact that it is very easy to do contributed to the myth. In addition, the fact that it is more difficult to install the thermostats and keep them in place on pre-'49 flathead fords than most other cars doesn't help either. |
#5 | |
Super Moderator
I had one car, a '34 coupe in which I'd rebuilt the engine, re-cored the radiator and rebuilt the pumps. Guys that know me, know I don't skimp / cut corners. That car would always push a little fluid out of the radiator after a decent drive. Removed the thermostats and no more issues. No, I can't explain the "why", but it worked. If I didn't know who built this car, I'd suspect underlying issues.
Didn't someone say that Henry never put more on a car than was needed? |
I tried the whole no thermostat thing when I was new to flatheads. The only thing I got was a car that wouldn't get over 120* when it was cold and ran 190* when it was hot out. I put 170*'s in it and it stays at 170* in all temperatures.
Been a while since I had Skip rebuild a set of 8ba pumps but IIRC the paperwork he sent back with the pumps said to not run thermostats. But as i said its bee a while.
Bottom line? If your car runs better all around without thermostats, there's something else wrong (dirty block or radiator, eroded impellors, cracked head or block, etc.).
When I built my '40 engine 25 years ago, I took extra time to make sure all the old core sand had been dug out from the water jackets, especially at the rear of the block. After that, I had the block baked at high temperature in a commercial oven at a machine shop that builds racing engines. The baking process turned all the scale and mineral deposits remaining in the water jackets into fine dust and was easily blown out with compressed air. After that, the machine shop then shot-blasted the block in a shot-blast cabinet and I can tell you that block was clean. I run Speedway water pumps and NO thermostats and have had no overheating problems - I live in Texas, so I know about hot! I check the temperature occasionally with a thermometer just for peace of mind, and have never seen it go over 180. I don't advocate running a flathead without thermostats, I just think it should be considered case-by-case based on the engines' condition. If your engine can handle them, by all means use them.
Ive run many cars wo thermostats.......
theyve always run cooler, so there you go..... |
#13 |
I tried no stats in the first 59AB I had built/ The motor tended to run hot which I attributed to the water moving to fast thru the radiator. I installed stats and the motor ran cooler at a more manageable temp.
#14 |
Millions of people drive billions of miles every year, and every one of those miles is done in a car with thermostats fitted. Every car that rolls off a production line has thermostats.
What is so special about a flathead Ford that would make it an exception to the norm? Run stats. It helps the motor in many ways. Mart. |
#15 |
#16 |
This we’ll be another myth but I was told that the thermostats not only got the engine up to proper operating temperature quickly but even open they restricted the flow so that the coolant spent enough time in the radiator to transfer the heat it had absorbed. But we weren’t talking about flatheads.
Cheers, Jim&Sandy McGregor, IA |
#17 |
As far as what Henry would think, what about the millions of engines Ford produced before adding thermostats in 1934? He must have changed his mind.
#18 |
I believe this proves the point. If everything had been fine, he never would have added them. He did not waste money on frivolous things.
#19 | |
Super Moderator
That car is still going strong w/o stats.
#20 | |
However, the O/P was asking about his '47 Ford (which did come from the factory with thermostats). Since the great majority of the members here have later model engines, I stand by my opinion. |
