Old 01-01-2023, 05:01 PM   #1
nkaminar
nkaminar's Avatar
Default Re: Coolant weep around head nut
If you are rebuilding an engine, use a bottom tap to clean out the threads in the block. Blow out the crap with high-pressure compressed air gun. A dental pick, available at auto parts stores, can also be used to clean out the bottom of the hole.
Old 01-01-2023, 07:27 PM   #2
mcgarrett
Good advice from all. I feel pretty sure using the Bars Leaks as previously mentioned will take care of the problem. I plan to add it to the radiator this week.
