Old 12-30-2022, 02:25 PM   #2
cas3
Default Re: 52 f1 steering box
Turning the screw in pushes the sector further into the worm to remove play. This must be done with the steering box set at dead center (wheels straight) . On or off the ground really shouldnt matter as you can only adjust the center and no need to spin the wheel lock to lock as the worm is looser at the ends of its travel by design.
