Old 12-14-2022, 11:26 PM   #1
Pete
Default ???
You are traveling down an abandoned air strip in your 30 model A 2 door at the speed of light and you turn on the headlights, what happens?
Old 12-14-2022, 11:29 PM   #2
johnneilson
Default Re: ???
You implode.
As Carroll Smith wrote; All Failures are Human in Origin.
johnneilson is offline   Reply With Quote
Old 12-14-2022, 11:36 PM   #3
Y-Blockhead
Y-Blockhead's Avatar
Default Re: ???
Depends on if the Sun is up or not.
Old 12-15-2022, 01:46 AM   #4
TomInCologne
TomInCologne's Avatar
Default Re: ???
...you have problems stopping your A with its tiny brakes due to the increased mass?
TomInCologne is offline   Reply With Quote
Old 12-15-2022, 03:25 AM   #5
Brad in Germany
Brad in Germany's Avatar
Default Re: ???
I have no idea. I'm still trying to figure out why we drive on parkways and park on driveways.....
Brad in Maryland
Brad in Germany is offline   Reply With Quote
Old 12-15-2022, 05:44 AM   #6
Oldbluoval
Oldbluoval's Avatar
Default Re: ???
I think you need more/better to ponder
But likely so do I as I’m posting!
No light comes on as you are same speed as light rays casting forward. Assuming the car hasn’t blown apart already
Oh time for my meds and nap….how about u?
Old 12-15-2022, 06:50 AM   #7
CA Victoria
CA Victoria's Avatar
Default Re: ???
I think the clue is in the movie “Back to the Future”
Tim
Downtown, Ca
CA Victoria is offline   Reply With Quote
Old 12-15-2022, 07:17 AM   #8
BRENT in 10-uh-C
BRENT in 10-uh-C's Avatar
Default Re: ???
Brad in Maryland
BRENT in 10-uh-C
www.model-a-ford.com
...(...Finally Updated!! )
Old 12-15-2022, 08:08 AM   #9
Stretch Cab
Stretch Cab's Avatar
Default Re: ???
Wouldn't the lights come on but not cast outward?
Let us live so that when we come to die, even the undertaker will be sorry. Mark Twain
Stretch Cab is offline   Reply With Quote
Old 12-15-2022, 08:43 AM   #10
McMimmcs
McMimmcs's Avatar
Default Re: ???
Worry not, there is help available for people with your kind of problems.
Old 12-15-2022, 08:48 AM   #11
RDVAARK
Default Re: ???
6 Volt positive ground? 12 Volt, negative ground? Generator or alternator conversion?
Real bulbs or LED?
RDVAARK is online now   Reply With Quote
Old 12-15-2022, 08:53 AM   #12
TomInCologne
Default Re: ???
Big difference between the Model T and the Model A there. The Model T was designed before the introduction of the Einsteinian physics. Therefore the Model T follows Newtons laws, whereas the Model A has to follow Einsteins laws. So, the Model T can accelerate faster than the speed of light...
Old 12-15-2022, 09:02 AM   #13
TerryO
TerryO's Avatar
Default Re: ???
Wow, how did you get your "A" to run that fast???
How far did it take you to stop???
TOB
TerryO is offline   Reply With Quote
Old 12-15-2022, 09:22 AM   #14
Elmo Rodge
Elmo Rodge's Avatar
Default Re: ???
The light would gather up in the buckets until they were full then spill over and burn your knees.
Wayno
Life is not a spectator sport.
Elmo Rodge is offline   Reply With Quote
Old 12-15-2022, 09:30 AM   #15
Badpuppy
Default Re: ???
How long is that air strip?
Why was it abandoned?
Old 12-15-2022, 09:30 AM   #16
zzlegend
zzlegend's Avatar
Default Re: ???
Nothing,,,,,,,,,,,,,,,,,,,,,,,,my headlights don't work.
zzlegend is offline   Reply With Quote
Old 12-15-2022, 09:48 AM   #17
1ton
Default Re: ???
You enjoy the moment until it's time to wake up.
1ton is offline   Reply With Quote
Old 12-15-2022, 09:55 AM   #18
Planojc
Planojc's Avatar
Default Re: ???
Nothing happens until you step out to check the fuse.
Planojc is offline   Reply With Quote
Old 12-15-2022, 12:41 PM   #19
veggie
veggie's Avatar
Send a message via AIM to veggie Send a message via Yahoo to veggie
Default Re: ???
Ask the barn for help!
veggie is offline   Reply With Quote
Old 12-15-2022, 01:33 PM   #20
sinbad339
sinbad339's Avatar
Default Re: ???
You, as the driver in the car, see the lights come on, and illuminate things in front of you. An observer on the airstrip doesn't see the lights come on, or any illumination.
"Our times are characterized by a perfection of means and a confusion of ends." - A. Einstein
sinbad339 is offline   Reply With Quote
