Old 11-11-2022, 10:14 PM   #1
fortyman
Default Coolant leak at Heat Exchanger
What would cause coolant to leak from where the heat exchanger ties in to the crossover pipe on a flathead v8?
fortyman is offline   Reply With Quote
Old 11-11-2022, 10:47 PM   #2
ford38v8
ford38v8's Avatar
Default Re: Coolant leak at Heat Exchanger
Pictures please.
Alan
Old 11-12-2022, 02:00 AM   #3
34PKUP
34PKUP's Avatar
Yes, how about a picture of this mysterious "heat exchanger" that ties to the crossover pipe??
34PKUP is offline   Reply With Quote
Old 11-12-2022, 09:03 AM   #4
tubman
tubman's Avatar
We realize that posting pictures to this forum can be problematic; some long-time users have trouble. If you are having these problems, we would at least appreciate a more complete description of the problem. What year and model of vehicle? I know of no stock application where the crossover ties into anything that has a connection to the cooling system, so this must be some aftermarket setup. The more detail you can provide, the better off we all are.
Old 11-12-2022, 10:03 AM   #5
Kube
Kube's Avatar
Yes, as others have stated, a photo would help.
However, knowing what a heat exchanger is (hot air heater part) and where it is, there are two likely suspects.
Most likely (I'm guessing here of course) the coolant is running down over the pipe and dripping from there. If that is in fact the case, look for a leaking head gasket.
If the coolant is leaking from inside the pipe, my guess is a cracked block.
Are you finding it necessary to add coolant to the system? Does the engine run hotter than it did prior to this leak showing up?
Have you inspected the entire area carefully? Usually, one can see a trail of sorts where the coolant has leaked and dried.
Hopefully, this is nothing more than a water pump leaking, blowing back, and dripping off the pipe.
Old 11-12-2022, 11:56 AM   #6
fortyman
Old 11-12-2022, 12:01 PM   #7
fortyman
Just figured out how to post picture. The liquid comes out the area where it looks like a slit in the heat exchanger unit that goes into the crossover pipe. I can't recall if the crossover pipe was in this same location or if the pipe could have slipped down some. It doesn't seem to be loose. The car is a 1940 ford v8 flathead. I have been restoring it for a few years and just got it running about a month ago.
Old 11-12-2022, 12:17 PM   #8
petehoovie
petehoovie's Avatar
Old 11-12-2022, 12:20 PM   #9
petehoovie
petehoovie's Avatar
Cold engine condensation?...And, I think you need a clamp at that location...
Old 11-12-2022, 01:19 PM   #10
Kube
Kube's Avatar
That cross over pipe is homemade obviously. I doubt it slipped down.
Are you losing coolant? That doesn't appear to be a coolant leak but rather, condensation.
Tell us more...
Old 11-12-2022, 01:36 PM   #11
ponymare
If it is coolant, there may be a crack in an exhaust port.
ponymare is offline   Reply With Quote
Old 11-12-2022, 02:23 PM   #12
marko39
Does the leak stop when engine is warmed up? A cold engine can piss out condensation for a good while while idling and not being driven.
marko39 is offline   Reply With Quote
Old 11-12-2022, 03:37 PM   #13
fortyman
I will run it some to see. Have not tried that.
Old 11-13-2022, 06:18 PM   #14
aussie merc
aussie merc's Avatar
if it dries out and dosent leave a trace line genaraly white or pinkish good chance its condensation
aussie merc is offline   Reply With Quote
Old 11-15-2022, 06:19 PM   #15
fortyman
Pic of what is leaking under car
Old 11-15-2022, 07:18 PM   #16
Kube
Kube's Avatar
Attachment 503353
Oh oh... not looking good.
Can you note any stains from above the pipe?
Old 11-15-2022, 08:42 PM   #17
fortyman
No stains or signs of leaking anywhere else.
Old 11-16-2022, 08:09 AM   #18
Kube
Kube's Avatar
Oh oh. I'm starting to lean towards a crack in the block.
Old 11-16-2022, 11:25 AM   #19
ford38v8
ford38v8's Avatar
fortyman, have you done anything with the exhaust manifolds? Anything with the mounting bolts of the exhaust manifold?
Alan
Old 11-16-2022, 10:15 PM   #20
fortyman
I have not. I did look at the oil dipstick and it is whitish.
