Hello,
I just purchased the Grease Fitting Set, Modern style for my 1928 I also got the press. My question to the crew here is, if I see threads on these can I use the press to put them into the holes that are on my front Brake actuator part. Thanks! |
Make sure they are threads and not ridges.
Press in have ridges. |
If the old fittings were not threaded,then tere are no threads.
The new style fittings I have used are too big and will not drive in. Try one,yours may be ok. John
Welcome each day |
I also can not drive in the new style fittings
That's my problem too!
Beste Gruesse aus Deutschland, Werner Ford Model A, Roadster, 1928 Citroen 11 CV, 1947 Hercules W 2000, 1976; (with NSU-Wankel Rotary Engine), Canadian version |
The front actuator has press in grease fittings. If you see threads then someone before you threaded them.
I used the press in new style by carefully using a grinder around the circumference to get a press fit. Trial and error.
John
Welcome each day |
When I rebuilt the front ends on my A's, I tapped the grease fitting holes and used the screw in grease fittings.
That is the best way to do it. On my parts the existing holes were too big fpr 1/8 pipe and not enough meat to go 1/4”.
Welcome each day |
