Old 10-27-2022, 08:51 PM   #11
19Fordy
19Fordy's Avatar
Default Re: Tell me about putting air ride on a 40?
Don't add air ride to a 40 Ford as you will destroy it. In order to lower a 40 Ford 6 in. you will need to install a complete Heidts frame for about $9K.
Read this:
https://www.fordbarn.com/forum/showt...1367&showall=1
The one below still has the stock frame and a solid axle. The front chin pan is 4 in. off the ground and the rear could be lowered more if the "rake" was not desired. Still has the stock drive train.
