Old 09-02-2022, 01:36 PM   #1
stevests
stevests's Avatar
Default Multiple Questions ?
1: Opinions on which pan gaskets to use - cork or paper ?
2: One piece or two piece crank pulley ?
Appreciate the input !
stevests is offline   Reply With Quote
Old 09-02-2022, 02:41 PM   #2
31Tudor
31Tudor's Avatar
Default Re: Multiple Questions ?
My vote:
1. Cork
2. One piece pully
31Tudor is offline   Reply With Quote
Old 09-02-2022, 05:25 PM   #3
CarlG
CarlG's Avatar
1) My engine builder used no gasket, just the black Permatex.
2) Definitely one piece pulley.
Alaskan A's
Model A Ford Club of America
Model A Restorers Club
Mullins Owner's Club
Old 09-02-2022, 05:51 PM   #4
Ray in La Mesa
Ultra Black Silicon & one piece pully.
Ray in La Mesa is offline   Reply With Quote
Old 09-02-2022, 05:52 PM   #5
stevests
stevests's Avatar
Much appreciate the input fellas !
Old 09-02-2022, 10:15 PM   #6
nkaminar
nkaminar's Avatar
The advantage with the two piece pulley is that it is easier to change just the pulley. But if you need to pull the second part it gets complicated. Most people weld something to the inner piece to pull it out.
Most cork gaskets are cork pieces in a plastic binder. The cork compresses more than the paper so it is better for surfaces that do not match properly, but you have to be careful not to over torque the fasteners or you will split the cork. The paper gaskets are better for parts that mate properly. You should make sure the surface of the pan is flat and fix it with a body hammer and anvil if not.
Smear a very thing layer of a silicone gasket sealer on both sides of the gasket. No silicone should squeeze out of the joint when the fasteners are tightened. If you use just the silicone gasket maker, then just tighten the fasteners until the surfaces are joined and the silicone is in full contact. Then let the silicone cure before fully tightening the fasteners and do not over tighten the fasteners.
Excess silicone gasket cement has been known to clog oil lines and cause damage.
Old 09-02-2022, 10:54 PM   #7
CWPASADENA
CWPASADENA's Avatar
Originally Posted by 31Tudor View Post
My vote:
1. Cork
2. One piece pully
I agree,
Cork is more forgiving than paper if the mating surfaces are not exactly flat. It is very hard to get the pain rails flat enough to easily seal well with paper.
I use Gask-a-Cinch sealer. It is a product that has been around a long time, seals very well and is easy to take apart when necessary.
Chris W.
CWPASADENA is offline   Reply With Quote
Old 09-03-2022, 12:39 AM   #8
Synchro909
Synchro909's Avatar
Originally Posted by CWPASADENA View Post
I agree,
Chris W.
Ditto.
When all is said and done, more is said than done. That's why we judge people on what they do, not what they say.
If I am not in trouble, I've done something wrong.
Old 09-03-2022, 07:37 AM   #9
rotorwrench
rotorwrench's Avatar
There are several types of paper but I wouldn't use it on a press formed sheet metal cover like the oil pan. The cork gasket form fits the pan better. A person has to evaluate the thickness of the gasket since it can make a difference on how much is trimmed from the rope seal. The thicker the gasket the less is trimmed from the rope seal. The rear main also needs a good cork gasket to seal properly but most pan sets have them even if the rail gaskets are paper. Most come with two widths for best fit in the main cap gasket channel.
Cork gaskets are a composite gasket. As was mentioned previously, cork particles are mixed with oil resistant elastomers (synthetic rubber). Some of the modern gaskets are pretty good. The last set I used was from Snyder's and they worked well. These are a bit different from the average cork types.
Paper gaskets work best on cast iron or steel covers. I use Three Bond 1211 on most gasket sealer situations. Copper sandwitch gaskets are a whole different animal.
The latest steel two piece lower pulley works well. The old die cast pulleys were crap.
Old 09-03-2022, 08:22 AM   #10
alexiskai
alexiskai's Avatar
It’s “Gasgacinch,” and I also use it almost everywhere a cork or paper gasket is used.
Old 09-03-2022, 10:24 AM   #11
stevests
stevests's Avatar
Again, I thank you all ! Been 50 years since I had an A in the shop !
