08-25-2022, 07:45 PM | #1 |
'56 Data Plate decoded.........
Hey Guys! Could someone please decode this '56 Sunliner plate?
VIN: M6GC107840 Body:76B Color: KV Trim:1K Production:157 Thanks in advance! - F F
1952 Ford F1 1965 Ford Falcon Sprint 2007 Ford Mustang GT |
08-25-2022, 08:42 PM | #2 |
Re: '56 Data Plate decoded.........
See if you can open this pdf file / link... a couple pages are fairly light due to the way it was originally copied (way before it ended up at this '55 Ford website) but it should have the info you need.
http://1955-ford.com/img-55-ford-dat...te-decoder.pdf) |
08-25-2022, 10:23 PM | #3 |
Well, according to that link, K= Fiesta Red , and V = Berkshire Green. Red & green tutone?
Na...only for Christmass! lol Doesn't make sense. As far as trim, I can't find anything. I checked the data plate again, and it is exactly like I reported in Post #1 above.
08-26-2022, 10:17 AM | #4 |
M - ENGINE - 292CI
6 - YEAR - 1956 G - ASSY PLANT - MEMPHIS C - BODY STYLE CODE - CONV 107840 - CONSECUTIVE UNIT NO. CODE 76B - F/L CONV COUPE Body:76B Color:KV Trim:1K Production:157 The EXT CLR and INT TRIM CODES are not jiving. Can you re-check or post a photo? What color is the car now? The PRODUCTION CODE was entered by each ASSY PLANT and varies in meaning.
***** - BILLBOARD FOR SALE - LEASE - RENT - OPTION TO BUY - - NO SOLICITING - (Unless A Cheap And Tawdry Bar Maiden ... ) - NO TRESPASS - FISHING - HUNTING - - NO NOTHING - - POST NO BILLS - ... Kilroy was here ... ... sigh ... |
08-26-2022, 03:44 PM | #5 |
Yes, I know they are not jiving. I have checked it 3 times.
Right now the car is Colonial White (upper body) & light/medium blue on the lower body. Looks like it may be Diamond Blue? The car is for sale @ Bills and Son Auto and Truck Sales. The car is in there inventory, and one of the pics shows the data plate. -F F
08-26-2022, 04:35 PM | #6 |
https://www.billsandson.com/details/...rlane/86982775 And photo of the Data Plate, a link and below... https://cdn05.carsforsale.com/358b3e...onvertable.jpg The lack of spacing of the characters on the second line of the plate could be confusing. 76B = Sunliner. Exterior Color, K = Fiesta Red Trim code, V = Red & White vinyl 1K = the scheduled build date, 1st day of October 157 = the production code. Fyi, the two rivets holding the plate on are generic pop-rivets, not original. If you're going to look at the car or are seriously considering purchasing it, double check that the serial number on the data plate exactly matches the serial number stamped into the right front top of the frame. . Last edited by dmsfrr; 08-30-2022 at 10:31 AM. Reason: punctuation |
08-26-2022, 05:27 PM | #7 |
dmsfrr - yes, it was the spacing that through me off, & could not make heads or tails of!
What got me digging into this was that: (A) I also noticed the attachment rivits. (B): Obviousally the interior was not original, so I could not help wondering if the exterior colors had been changed. Thanks! - F F
08-26-2022, 07:18 PM | #8 |
G indicates Chicago plant, not Memphis. My '55 was built at Memphis, and M is the code for Memphis plant.
08-26-2022, 09:22 PM | #9 |
That's my mistake ...
08-26-2022, 09:28 PM | #10 |
Well, if the plate actually belongs to the car, the EXT COLOR (K) was FIESTA RED and INT TRIM (V) was RED & WHITE VINYL. Those are seat covers but if that was a color change, somebody had to do some serious work.
That and the rivets give me pause. The actual correct rivets are available. Clear title or salvage? EDIT - The ad says 312 while the VIN says 292.
***** - BILLBOARD FOR SALE - LEASE - RENT - OPTION TO BUY - - NO SOLICITING - (Unless A Cheap And Tawdry Bar Maiden ... ) - NO TRESPASS - FISHING - HUNTING - - NO NOTHING - - POST NO BILLS - ... Kilroy was here ... ... sigh ... Last edited by KULTULZ; 08-26-2022 at 09:40 PM. |
08-26-2022, 10:17 PM | #11 | |
08-27-2022, 10:10 AM | #12 |
This is an excerpt from the 1955-56 PATENT PLATE TECH SHEET given above -
I wonder ... ... what is meant as a RH side member?
08-27-2022, 10:51 AM | #13 |
You guys have to check out this page -
http://1956-ford.com/1956-ford-car-data-plate.html Go to his HOME PAGE also. Also read this ... https://www.fordbarn.com/forum/showt...68#post2160868 Last edited by KULTULZ; 08-27-2022 at 11:00 AM. |
08-27-2022, 01:24 PM | #14 |
Somewhere on the right front frame rail between the firewall & front bumper.
This is the location on '55/'57 T-Birds, below the heater fan. Usually covered with paint and ??? There is another location, maybe two, stamped into the frame before the body is put on. . Last edited by dmsfrr; 08-28-2022 at 08:15 AM. Reason: add photo |
08-27-2022, 07:18 PM | #15 |
it is on the top of the right frame just back from where the bumper bracket bolts on there is a star before the numbers some of the factorys put them on top of the frame that hold the rear shocks on also on the rear frame of the car body off then you can see them the numbers will match the data plate i have also seen them ground off smooth so the frame does not match the title
08-28-2022, 01:54 AM | #16 | |
I guess a side member is another descriptive name for a frame rail ...
08-29-2022, 12:25 AM | #17 |
The data plate numbers on the frame are not visible unless you remove the passenger side bumper bracket to view the one on the frame side rail, and for the one on top of the front passenger side frame rail, you need to pull back the rubber weatherstrip (if possible). That weatherstrip is stapled to the bottom of the front fender inner apron. Be careful not to break the rubber strip off in case it might be brittle by now. Probably easier to remove front bumper brackets on passenger side.
08-30-2022, 06:24 AM | #18 |
Another good vin decoder site...
http://vinmagic.com/1953-1959-ford-vin-decoder/ |
