Old 07-31-2022, 07:46 PM   #1
Duke
Default Rust pit in new bearing race?
I purchased some NOS bearings and races for my late 32 banjo. I was installing them today and when I cleaned the old packing grease on one of the races that goes in the axle tube I found two small rust pits. I think it is likely not a good idea to use it or am I worrying about nothing? These are old parts in old Ford boxes.
Thanks
Duke is offline   Reply With Quote
Old 07-31-2022, 07:50 PM   #2
cas3
Default Re: Rust pit in new bearing race?
Can you feel them with your finger nail? I would be tempted to use them being the cheap ass that I am. Prolly still better than the chinese bearngs
Old 07-31-2022, 07:52 PM   #3
Jack E/NJ
Jack E/NJ's Avatar
>>>I found two small rust pits.>>>
One picture is worth more than six words. 8^)
Old 07-31-2022, 07:54 PM   #4
Lawson Cox
Lawson Cox's Avatar
Two "small rust pits" wouldn't cause me to skip a heart beat or lose a wink of sleep over it. Honestly, or as my two year old daughter, who is now 58 used to ask, "Really and lively, daddy?" Yes, "really and lively". Go for it.
Old 07-31-2022, 07:56 PM   #5
VeryTangled
VeryTangled's Avatar
A fella can get a bunch of tips on how to post pictures by watching this seven minute video. https://youtu.be/CGijbl1bfnI
-Jeff H
Old 07-31-2022, 08:03 PM   #6
Duke
Here is some pictures, yes I can feel them.
File Type: jpeg 910F7759-4D97-4BB9-9953-4896DAD96D6E.jpeg (63.0 KB, 272 views)
File Type: jpeg DE748F7F-0AAD-4120-AE5E-9DE727D3AB4B.jpeg (67.5 KB, 260 views)
Old 07-31-2022, 08:05 PM   #7
petehoovie
petehoovie's Avatar
USE THEM!
Old 07-31-2022, 09:55 PM   #8
David J
David J's Avatar
Surface is not compromised so i would call it an " oil retention groove " .
Much rather use that NOS one than modern crappola.
David J is offline   Reply With Quote
Old 08-01-2022, 12:01 AM   #9
Duke
Makes me feel better. I have never done this before and am learning as I go.
Thanks
Old 08-01-2022, 02:45 AM   #10
Mart
Mart's Avatar
Scrape a razor blade across the surface to make sure nothing is sticking up.
Old 08-01-2022, 08:23 AM   #11
Bored&Stroked
Bored&Stroked's Avatar
Those bearings are not easy to find and NOS ones are the only way to go. Clean any rust that is on them off (maybe some Scotchbrite) and you should be good to go.
Also, make sure your pinion pre-load is correct and that your ring and pinion mesh is correct. You'll need to get some of the "yellow stuff" to check out the contact pattern and take the time to get the side gasket thicknesses correct (side to side).
You can't just put it back together the way it was (though the original gasket thicknesses are nice to know).
Old 08-01-2022, 08:24 AM   #12
Bored&Stroked
And make sure you replace the outer axle seals - not hard to do, just need to make a tool to drive them in place.
Old 08-01-2022, 09:38 AM   #13
Tim Ayers
That's the problem with that cosmoline product they used back in the day. I've purchased NOS engine bearings (much softer than your race) and they were ruined after getting them cleaned.
The cosmoline eat into the bearing surface. Not sure what it is made of, but years of sitting around in it is actually not kind to delicate metal surfaces.
Old 08-01-2022, 11:35 AM   #14
Duke
Any good tech on how to do this? I have read the really good model a write up. I was going to build the tool out of an old spider cross, but it is too hard to drill. The old service bulletins talk about doing it by feel?
Old 08-01-2022, 12:17 PM   #15
Bored&Stroked
I believe that VanPelt may have a book on rebuilding a rear - as well as maybe Vern Tardel.
You need to be able to set the pinion preload - can be done a variety of ways. I use an inch-lbs torque wrench. I first use it to set the pinion preload, then I also use it to see what type of overall preload the whole mess has (when setting side clearances). It is very important that you setup the gasket thicknesses on each side to get the proper gear mesh, backlash and overall preload.
I have a couple good articles/threads I scavenged over the years - will probably help you a bit. Also, the guys who build quick changes tend to create quite a few good articles on these types of rear ends (even though they are quick changes they're working with). The principles are much the same.
Drop me a DM with an email and I'll forward you a few that should help you. The one from 'Winters' includes a section for setting up a V8 quick-change, review the specs there - very similar to a V8 banjo.
Take care,
B&S
