Old 07-29-2022, 11:55 AM   #1
Ramblin Reck
Ramblin Reck's Avatar
Default Generator or Alternator, that is the question.
Can it be positively identified?
Is it a Generator or an Alternator on my 1939 Ford] Convertible with a replaced flat head engine. The engine is a 1947 or '48, 100HP, 59A-B, replacement with 12Volt, Positive Ground. There are no markings on it or evidence of tags removed. Previous owner has gone on to the Big Junkyard in the Sky with the sign that says "Take what you need!"
Thanks y'all!
"Engineers like to solve problems. If there are no problems handily available, they will create their own problems!" ROGER, WILCO, OUT!
Ramblin Reck is offline   Reply With Quote
Old 07-29-2022, 12:52 PM   #2
deuce lover
deuce lover's Avatar
Default Re: Generator or Alternator, that is the question.
Looks like a generator.Is there a voltage regulator on the firewall?
Old 07-29-2022, 02:11 PM   #3
jayvee34
jayvee34's Avatar
Based on the middle photo, it looks like a generator due to the length of it.
The "power gen" (generator/alternator look alike) is shorter and somewhat fatter.
If you have a voltage regulator on the fire wall, would just about confirm it to be
a generator.
IN GOD WE TRUST - SEMPER FIDELIS
John
jayvee34 is offline   Reply With Quote
Old 07-29-2022, 02:52 PM   #4
Ramblin Reck
Yes sir, there is a 12v Regulator on the wall.
Old 07-29-2022, 02:59 PM   #5
Ramblin Reck
a generator.
Roger that Jayvee, a 12v Regulator is on the firewall. I measured the length and it is 8.5" from the back to the end of the pulley. Hope this finds you well my friend!
Old 07-29-2022, 10:25 PM   #6
cas3
It would be odd to go 12 volt and stay positive ground. Usually the reason to go 12 volt would be to run modern accessory's, but that would require negative ground also. I would be tempted to have a look inside
Old 07-29-2022, 10:48 PM   #7
cadillac512
cadillac512's Avatar
Simple test: An alternator will have power all the time to the output post. A generator will only have power there with the car running.
Terry
"It don't take but country smarts to solve the problem" (Smokey Yunick)
'41 Merc Town Sedan / 260" 8CM engine
'66 Fairlane four door / "warmed up" 302
cadillac512 is offline   Reply With Quote
Old 07-30-2022, 07:19 AM   #8
Ramblin Reck
No doubt about it, that it is Positive Ground. Follow the Red Wire from the post to the firewall. Follow the Black Negative wire to the Solenoid. What are you suggesting that I "should look into?"
Old 07-30-2022, 08:47 AM   #9
terry
Don't fix what ain't broken. I went with 12v positive ground for for quite a few years on my 36 Ford. terry
terry is offline   Reply With Quote
Old 07-30-2022, 09:06 AM   #10
Ramblin Reck
Terry
Are you referring to one of the two posts shown in this pic on the round black thing which may be a Generator or maybe an Alternator or are you referring to the battery posts?
Old 07-30-2022, 09:09 AM   #11
Ramblin Reck
Terry
Thanks I agree with you 110%!
Old 07-30-2022, 11:17 AM   #12
cadillac512
The posts in your pic....but never mind. I can see the commutator and part of a brush through the opening in the housing. It's a generator for sure!
Terry
Old 07-30-2022, 08:15 PM   #13
Newc
Newc's Avatar
An alternator will bump your car to Touring A Class with all the hotrods for V8 Judging. Newc
Old 07-30-2022, 09:54 PM   #14
cas3
Not my Whitney conversion, you wouldn't know it was there unless I told you
Old 07-31-2022, 01:13 AM   #15
Tinker
Tinker's Avatar
Depends on what you want or going for.
Old 07-31-2022, 07:18 AM   #16
Ramblin Reck
Terry
Terry
Thanks I feel much more confident calling it a Generator now
Old 07-31-2022, 03:02 PM   #17
jayvee34
jayvee34's Avatar
Smile Re: Generator or Alternator, that is the question.
Thanks for asking. Doing very well my friend.
John
Old 07-31-2022, 08:38 PM   #18
dakotafarmboy
dakotafarmboy's Avatar
Cadillac….I loved the quote from Smokey Yunick. He has to be my favorite stock car celebrity! He could go a ways further on a tank of gas than anybody else one Sunday and he got inspected after the race. He was running a 2 inch fuel line!! Smokey correctly pointed out that his tank was within specs. NASCAR put a rule in the next day that limited the size of the fuel line…
dakotafarmboy is offline   Reply With Quote
