This bolt pattern jig is a good option if the diameter of the bolt surface of the rotor is large enough and the wire wheel bolt circle has sufficient contact to the re-drilled rotor.
https://m.roadkillcustoms.com/wheel-...ill-guide-jig/ Last edited by glennpm; 07-19-2022 at 08:20 AM. |
