Hey all, in the process of replacing my tires. I have 4 new Firestones ready to go.
I want to install period accurate valve stems in the tubes. Does this look correct for my 1930 Roadster? https://www.mikes-afordable.com/product/M1500BK.html |
https://www.brattons.com/30-31-METAL...ductinfo/2240/
What you have is correct, but is missing the actual valve stem. See link |
Are you looking for original stems and hardware or new replacements?
I think the short dust covers are out of stock everywhere.
#6 | |
I have never used these. Do they seal well? Do you need to use some sort of adhesive or sealant? Why were they used originally? Could they be used to fix a tube that had a bad rubber valve stem?
#8 | |
![]() Quote:
Not sure why they were used originally, but I would guess that it was because the processes to make a rubber valve stem did not exist or someone had not invented that yet. Can they be used to fix a tube that had a bad rubber valve stem? Probably. It depends upon where the problem is. You remove the original stem entirely. There must be a video of it somewhere. There was a discussion of how to do this at the MARC meet valve stem seminar in Morgantown in June.
1910 Model T Touring 1924 Model T Coupe 1928 Model A Roadster 1930 Model A Town Sedan 1939 Deluxe Fordor 1945 pickup 1951 Custom convertible |
#10 | |
![]() Quote:
https://www.amazon.com/Milton-473-Pa...%2C576&sr=8-13
I've used the replacement stems & they work fine. I put some of Snyder's replacement '30 stems in my tubes, bought them 30 years ago at 1/2 the price they are now & they worked fine with no sealant, but, I had to fix three pin hole in the NEW tubes I bought 10 years ago.
Thank you all. Some great discussions. I found the metal stems at Bert's and they are on the way. Will have to run without the dust covers until they're available once again.
