Old 06-29-2022, 11:37 AM   #1
bigd1101
bigd1101's Avatar
Default Lost clip......
Of course, while moving the small rod on the carb ( I believe the accelerator pump) attempting to put the tiny clip back on it went "ping" into the great unknown! The pic shows the small hair-pin clip. Does anyone know where I can get a replacement and the size of this little guy?
Don
bigd1101 is offline   Reply With Quote
Old 06-29-2022, 11:46 AM   #2
Vics Stuff
Vics Stuff's Avatar
Default Re: Lost clip......
As a recommendation , Go on E bay look up hairpin clip. A great resource on that site.
Vic
Vics Stuff is offline   Reply With Quote
Old 06-29-2022, 11:55 AM   #3
rockfla
rockfla's Avatar
MSC or McMaster Carr, Amazon, EBay, NAPA-Take that picture and the diameter of the shaft with you to the local NAPA, bet they have "something" for you!!!
Old 06-29-2022, 12:15 PM   #4
Merc Cruzer
Merc Cruzer's Avatar
Ace Hardware has them for sure. While I was there, I also picked up a couple for the distributor vacuum arm, and they are allot smaller.
Merc Cruzer is offline   Reply With Quote
Old 06-29-2022, 01:40 PM   #5
Mart
Mart's Avatar
There might be one in a carb kit, if you might have one already.
Old 06-29-2022, 01:42 PM   #6
Scott52
I just entered carburetor linkage clip and a bunch came up. Napa had them.
Scott52 is offline   Reply With Quote
Old 07-01-2022, 02:56 PM   #7
B-O-B
B-O-B's Avatar
Any one of the carb builders probably have them.
B-O-B is offline   Reply With Quote
Old 07-01-2022, 03:02 PM   #8
cas3
I would just put a cotter pin in there. Easy to get, and they dont fly away
Old 07-01-2022, 03:10 PM   #9
mike in tucson
Commonly called a "Jesus" clip because when it pops off and flys away,
you usually say "Jeeze"
mike in tucson is offline   Reply With Quote
Old 07-01-2022, 05:18 PM   #10
34PKUP
34PKUP's Avatar
Don't believe I have ever seen that model carb. that has a cotter pin hole.
(unless you just like extra work?)
34PKUP is offline   Reply With Quote
