Old 06-25-2022, 11:59 AM   #1
JRShaw
JRShaw's Avatar
Default Another standard roadster top question!!
Gentlemen: I have enclosed a couple of pictures that show the side links which connect to the back of the top irons. There are pins just to the right of my labels. The pin is about .255/.260" in diameter withe an almost spherical end. The height of the pin is about .300/.310" tall. QUESTION: Do these pins remain in the top when it is being closed?? A friend told me that the pins are to be pulled out when closing the top. Thank You in Advance!!
Joel R. Shaw
Fairport, N.Y.
JRShaw is offline   Reply With Quote
Old 06-25-2022, 01:55 PM   #2
Pamodelaroadster
Pamodelaroadster's Avatar
Default Re: Another standard roadster top question!!
Yes, the pins have to be pulled out for the top to come all the way down, And I mean simply separated from the second piece they go into.
Pamodelaroadster is offline   Reply With Quote
Old 06-26-2022, 02:01 PM   #3
jmalex1929
Do you know of someone that makes the top bows for the 30 standard roadster? If not, could you take the measurements of the bows so that i can try to make a set.
Thanks,
Jesse
jmalex1929 is offline   Reply With Quote
Old 06-27-2022, 09:24 AM   #4
JRShaw
JRShaw's Avatar
Smile Re: Another standard roadster top question!!
Thank You Very Much!! This is good information. Take Care.
