Old 06-13-2022, 01:00 PM   #1
lotsagas4u
Default Accelerator/spark rods?
Who has the best quality control rods available? Is the correct length of accelerator rod 10 1/2?
Thanks
lotsagas4u is offline   Reply With Quote
Old 06-13-2022, 01:05 PM   #2
1931 flamingo
1931 flamingo's Avatar
Default Re: Accelerator/spark rods?
Most likely only one manufacturer.
Paul in CT
Old 06-13-2022, 03:46 PM   #3
Gary WA
Gary WA's Avatar
Thanks
As per standards A-9747 10-1/2" Cadmium plated
www.whidbeymodelaclub.com
Old 06-14-2022, 07:02 AM   #4
BRENT in 10-uh-C
BRENT in 10-uh-C's Avatar
This is another one of those times when 'my research' counters what is printed in the "Standards". Choose whatever length you feel is correct for your vehicle.
BRENT in 10-uh-C
www.model-a-ford.com
...(...Finally Updated!! )
Old 06-14-2022, 09:02 AM   #5
Planojc
Planojc's Avatar
I just received the set of three rods from the only supplier that had them in stock. All worked but I had to enlarge the hole on the spark rod where it connects to the distributor and bend it at an angle to get it to stay on. The rod to the carb. was a little too long so I bent the arm where it connects to the pedal assy.
Planojc is offline   Reply With Quote
