Old 06-10-2022, 05:11 PM   #1
Daba
Default 1930 Tudor wire harnesses
I recently became the proud owner of yet another Model A (#7) this one is a 1930 tudor. The harness that is in it is all cobbed together, I have replaced harnesses several times and have never come across this problem, it has two bulb headlights and cowl lights I cannot seem to find a harness that will cover both, did somebody add one or the other that don’t belong?
Thanks again. Daba
Daba is offline   Reply With Quote
Old 06-10-2022, 05:34 PM   #2
Bob C
Default Re: 1930 Tudor wire harnesses
Should only have one or the other not both.
Old 06-10-2022, 05:45 PM   #3
Big hammer
And that’s why it was cobbled together!
get a bigger hammer tap done
Old 06-10-2022, 06:26 PM   #4
Daba
OK thank you I will go with one light in the headlight. The Cowl lights are in very good shape and the holes are already there looks like they’re going to win.
Thanks again
Old 06-11-2022, 09:58 AM   #5
Badpuppy
Some use the cowls for turn signals, front socket for park.
Old 06-11-2022, 08:03 PM   #6
Planojc
Planojc's Avatar
On my two bulb harness I just added another wire from the parking light switch contact post to the cowl lights.
Planojc is offline   Reply With Quote
