Old 06-03-2022, 01:38 AM   #13
redmodelt
redmodelt's Avatar
Default Re: Timing issues, Bosch magneto/ laurel cylinder head
Compression test will not find vacuum leaks, will tell you if there are valve issues as would a leak down test. Vacuum leaks would be carb or manifold gaskets not sealing or worn hole where the throttle shaft goes through on the carb.
