05-02-2022, 06:35 PM | #1 |
Modern Bendix
What is the correct procedure to replace the original Model A bendix with the new modern bendix. Thank you.
05-02-2022, 07:57 PM | #2 |
Re: Modern Bendix
The parts vendors that sell this item can probably provide instructions on how to install it. Also, have you checked YouTube?
05-03-2022, 12:05 AM | #3 |
Re: Modern Bendix
Instructions from Snyder's on-line catalog; https://www.snydersantiqueauto.com/c.../A-11350-M.pdf
05-03-2022, 03:37 AM | #4 |
Re: Modern Bendix
I've discovered the procedure is to buy at least two as they appear to be a bit fragile. Once you fit the second one, take a moment to rebuild an original in time for the next failure...
05-03-2022, 07:03 AM | #5 |
Re: Modern Bendix
A spring loaded collar covers the set screw that is used to attach the drive. The spring is strong and so the collar is hard to move. I use my vice to move it back and then unscrew the set screw a little to keep the collar moved back. Then install the drive on the shaft so that the set screw will insert into the hole in the shaft were the bolt for the spring went. Don't forget the key. Screw the set screw down tight using the screw driver to keep the collar from moving. The collar will spring into position to keep the set screw from coming out.
The starter with the modern Bendix drive is a little harder to install. It may be necessary to remove the coolant inlet, after draining the radiator, and removing the dip stick. Try installing it first without removing the inlet. Turn the starter over by hand before installing the new drive to check to see if the shaft is bent. I have not found the modern drive to be fragile. Maybe the ones in the UK are different.
A is for apple, green as the sky. Step on the gas, for tomorrow I die. Forget the brakes, they really don't work. The clutch always sticks, and starts with a jerk. My car grows red hair, and flies through the air. Driving's a blast, a blast from the past. Last edited by nkaminar; 05-03-2022 at 07:14 AM. |
05-03-2022, 01:22 PM | #6 |
Re: Modern Bendix
05-03-2022, 01:31 PM | #7 |
Re: Modern Bendix
I personally am not a fan of the replacement bendix. I would never install one on any of my cars. i recently worked on a friends car that had one, and nkaminar is right, I had to take the water inlet off just to get the starter back in. Pretty simple otherwise. I have pretty good luck with the originals, even starting the 12 volt speedster.
05-03-2022, 01:33 PM | #8 | ||
Re: Modern Bendix
Just messin' with ya 31Tudor. I agree, a little harder to install but I still prefer the modern drive.
The Master Cylinder Enjoying life at the beach in SoCal... Last edited by The Master Cylinder; 05-03-2022 at 02:07 PM. |
05-03-2022, 06:58 PM | #9 |
Re: Modern Bendix
The modern drive breaks as well. It just doesn’t drop the bolt head down in the housing. I take my starter out every few thousand miles and check if the bolts are starting to get loose. I have a 1/4” flex cable with a small earth magnet on the end. It will fish the broken bolt out a one or two tries through the starter hole. It’s also pretty easy to start your car with a hand crank if you have to.
