Any info on an oil pump out of a 59a i'm building?
Casting numbers are W pre-fix. Unlike the others i have, this body looks die cast alloy, cast iron end cover, cast iron elbow with die cast pick up bowl. Dimentionally the same as any other 59a pumps. No wear what so ever, factory spec backlash and tooth to housing clearance. |
Post some good pictures . . .
Personally, I don't think I would want any die cast inside my motor
cas3 makes a good point, I think.
#7 | |
![]() Quote:
Since you see no wear what so ever I take it you mean it has been run was it in the 59A your building? Ronnieroadster
I use the F word a lot no not that word these words Flathead , Focus and Finish. "Life Member of the Bonneville 200 MPH Club using a Ford Flathead block" Owner , Builder, Driver of the First Ford Flathead bodied roadster to run 200 MPH Record July 13, 2018 LTA timing association 200.921 in one and a half miles burning gasoline. First ever gas burning Ford flathead powered roadster to run 200 MPH at Bonneville Salt Flats setting the record August 7th 2021 at 205.744 MPH |
![]() OHV DeLuxe .....If you are by chance having difficulty posting pictures of that "CAST" oil pump, e-mail them to me and I'll post 'em here for you. My e-mail BELOW: [email protected] Coop . |
Pictures.
3 more
That’s a stock 41A-6600 Oil pump 80 lb
They were die cast?
#13 |
Cast iron
#14 |
This is die cast, not cast iron like the 25 others i have that are both both pre war and post war.
Only cast iron part on this is the end cover and the bolt on pick up elbow. Last edited by OHV DeLuxe; 04-27-2022 at 05:02 PM. |
#15 |
Really? Try holding a magnet to it.
#16 |
It is not magnetic at all, i know my metals, this is absolutely die cast white metal.
#17 |
#18 |
Can it be an oil pump made in Germany? The "W" marking in the castings may be a specification used for the german army W=Wehrmacht.
#19 |
That has been my theory too, i do have other German oil pumps here though, they are all steel like the American and English pumps.
The German and English books and manuals does not show this either. A very strange find. |
