03-14-2022, 05:56 PM | #1 |
1940 Ford wheels?
I have two 6.00 x 16" Ford wheels with dates of 11-18-40 and 11-19-40 stamped on the wheels. Would I be correct in assuming by the dates being so late in the year that they would be for use on 1941 Fords?
03-14-2022, 06:17 PM | #2 |
Re: 1940 Ford wheels?
Production of 1940 Ford passenger cars was for pretty much ceased by October, 1940.
So yes, you'd be correct in assuming your rims would have been installed on a '41 Ford. Other than the date codes, the rim design is the identical to 1940.
03-14-2022, 06:23 PM | #3 |
I was pretty sure that was the case and it makes sense.
04-07-2022, 02:42 PM | #4 |
6" wide 1940 wheels? Are you sure? If they really are, they have to be rare commercial wheels, and are probably very valuable.
04-07-2022, 03:03 PM | #5 |
My guess? The original poster was measuring the very outside width.
04-07-2022, 03:14 PM | #6 | |
Paul J. |
04-07-2022, 03:38 PM | #7 |
Tire size 6.00 x 16 is my guess
04-07-2022, 07:00 PM | #8 |
A good and reasonable guess for certain.
I'm going with my theory still. The poster did state "wheel"- not tire. Still, anyone's guess...
04-07-2022, 08:12 PM | #9 |
Sorry, I just got excited. The wider steel wheels of the era are very coveted, and some with 1940 dates sounded like a real oddity.
04-08-2022, 07:18 PM | #10 |
The wheels I was referring to in my original post are designed to fit tire size 6.00x16.
04-08-2022, 07:51 PM | #11 |
1940 Ford Deluxe 16 Inch Wheel |
04-08-2022, 11:00 PM | #12 |
Ain't that pretty? It just so happens that that particular wheel/tire is the original spare out of a '41, although it is the same wheel as a '40. Note the "FORD" script on tire at about one o'clock! Coop . |
04-08-2022, 11:58 PM | #13 |
I have a ford script tire, well not mint like that one, but it is ford script !
04-09-2022, 12:17 AM | #14 | |
Note how the lugnut hole on the '40 and the '41 wheels have the normal taper on the inside of each lugnut hole, but the '40 & '41 Wheels do NOT volcano-out around each lug hole, as my picture of a '46 wheel below is, but instead the '40 & '41 wheels are FLAT around each lugnut hole. Click on picture to Enlarge
If mama ain't happy, ain't nobody happy. But if daddy ain't happy...RUN What I GOT DONE TODAY... I put my rear-end in the recliner, and now I'm going to rest up & watch TV. |
04-09-2022, 12:29 AM | #15 |
1946 Ford Wheel Centre showing taper of Wheel Stud Holes - different from the 1940-1941 Ford Wheels. Lanny |
04-09-2022, 08:32 AM | #16 |
Good guess! Winner, winner, chicken dinner!
04-09-2022, 08:45 PM | #17 |
I got lucky ! ...once
04-10-2022, 10:01 AM | #18 |
Since we are discussing "original" 40 wheels, I think this is a good place to ask the expert about the changes in 41. The way I understood it was the 40 wheel was 4" wide, with the drop center having square sides on front and back. But in 41 they were 4" with a square drop on the front and a taper on the back. What say you Kube?
04-10-2022, 10:24 AM | #19 | |
alchemy ....Do you actually have a 4-INCH wheel with drop center square in front, and tapered in rear? I have never seen a 16" (4" wide) Ford wheel like that. Coop . |
04-10-2022, 10:33 AM | #20 |
Tapered on one side are 4.5" wide I always thought. I had not ever noticed the different stamping around the stud holes though, so I have learned something new here
