Number 3 on the rebuild papers also indicate to resurface, I'm posting this to try and help others as well as me, don't get me wrong it's great to send every part you need rebuilt to someone else, but sometimes it's not financially visible,
for me to send water pumps to get a rebuild It would be around $400 that does not make sense to me. |
#2 | |
![]() Quote:
#3 | |
![]() Quote:
Skips pump rebuilds are a work of art. Better impeller nice and tight on the seal. I have a set of new aftermarket to compare to Skips and there is no comparison. I’m not sure if any of the aftermarket suppliers have the better impeller separate or water pumps with them. I have a pump kit but have been told that it can be fairly difficult to get the pulley off with out it breaking. |
As I remember, you drill the impellor off, and then press the bearing out from the back. Then it is easy to set up to press off the pulley. I'm talking about a Ford bearing type (truck) pump as an example.
This reamer is just to give you a flat clean surface for the seal to run against, similar to one used to repair the seat in a water tap. |
