Old 03-10-2022, 06:24 PM   #21
fordv8j
fordv8j's Avatar
Default Re: Gas millage
Our 2 38s get about 16mpg
fordv8j is offline   Reply With Quote
Old 03-10-2022, 06:35 PM   #22
Karl
Karl's Avatar
Default Re: gas millage
You guys don't know how lucky you are at $5 Canadian per UK gallon !!
Gas in New Zealand is the equivalent of $13 Canadian dollars per UK Gallon
Karl
Such a fine sight to see-Its a Girl, My Lord, in a Flatbed Ford slowin' down to take a look at me.
Karl is offline   Reply With Quote
Old 03-10-2022, 07:50 PM   #23
38 coupe
38 coupe's Avatar
I had a fresh tune up in a stock 50 sedan with overdrive. Steady 50 mph in overdrive was 22 miles per gallon.
My 53 sedan with 215 OHV six and overdrive will get a little over 20 if I keep it under 65, but drops to 18.5 at 75.
Overdrive and slow speeds are your friend if mileage is a big concern, but how many miles do you have to drive to pay for the overdrive?
Old 03-10-2022, 08:02 PM   #24
B-O-B
B-O-B's Avatar
Install a sail. Wind caught me today & I had to put the brakes on , while using my walker.
B-O-B is offline   Reply With Quote
Old 03-10-2022, 10:20 PM   #25
Tinker
Tinker's Avatar
Not sure I've made the effort to know.
My older f150 gets 13mpg. So anything above that is gravy to me.
Need a electronic runaround car to offset my day to day. I don't need a big gas truck to go to pick up groceries. But it certainly helps the few times I need gravel or pull a boat.
Old 03-10-2022, 10:39 PM   #26
Lawrie
Lawrie's Avatar
Tinker , I had a v12 jaguar sedan for a long time and any thing under 22litres /100 klms is good for me after that,
Lawrie
Old 03-10-2022, 11:19 PM   #27
Tinker
Tinker's Avatar
Lawrie with all that fluid and distance metrics I'm going to have to do some conversions.
Old 03-10-2022, 11:33 PM   #28
Tinker
Tinker's Avatar
I'm probably crossing a line but if you have read the US 2021 national intelligence council 4 yr report. It stresses that alternative fuel is key to national security.
For 50 yrs the policy was to use others oil instead of ours. But the US is the number 1 exporter. So... why is gas high here or our buddies??? Policies and politics aside.
Old 03-10-2022, 11:34 PM   #29
fordor41
fordor41's Avatar
we drove our '41 fordor from Ny to Fla, 302, 2brl, 2:73 gears and got 24.5 MPG.
fordor41 is offline   Reply With Quote
Old 03-10-2022, 11:41 PM   #30
Tinker
Tinker's Avatar
Think about energy as a centralized power plant is an old idea. If every one had one solar panel on their house it would reduce the idea of power only delivered by one controlling entity. I'm sure the power companies and the lineman will do just fine managing the grid lines.
Don't worry however, they will figure out to tax for lost revenue from gas. Republicans in minnesota are already floating a bill to tax electric vehicles to off set gas taxes.
Old 03-10-2022, 11:58 PM   #31
Ol' Ron
Ol' Ron's Avatar
If the price of gasoline staus high in the future. more guys will begin tuning their engines. This takea some exoerimentin, bt the theory is to burn a lean mixture. This takes allot of ignition advance. and the spark plug location becomes an issue. i have 2 engines in the works right now , both are 258 ci displacement . The first one will have the experimental LS intake style port yjr other is waiting for that Information. With a cam change the Cr increased It can be used to check fuek mileage. This will require a dist like Charley makes and a better carb. I;ll start with a 2GC. Some people here are running EFI systems and they can give us the timing numbers to get into the 15.5/1 CR range the modern cars run in creise.
Gramps
PS some are even higher than that???
Old 03-11-2022, 12:05 AM   #32
Tinker
Tinker's Avatar
Ron. I have always respected/enjoyed your prospective of efficiency and performance detail.
Old 03-11-2022, 12:55 AM   #33
Kurt in NJ
Kurt in NJ's Avatar
So now 60hp cars may become more valuable ---the 39 4 door with stock 60 hp once I learned how to drive it got 25+ mpg keeping it under 60. anytime it dropped to 40 on hills downshift to 2nd --it would take less throttle to go 45 in second than 40 in third on hills.
just under 20 mpg at 70 ---this car drove and rode really nice on the highway --fuel mileage documented with long term fuel useage records
Old 03-11-2022, 01:06 AM   #34
Tinker
Tinker's Avatar
Around here everyone drives jacked up trucks with v8's. Few need it other then it's cool most of the time. It's hard not to understand reality and want to feel a bit despondent when they bitch.
For some, the second largest investment they make is a vehicle. It's just a depreciating asset, transportation. In Florida we always joked about seeing corvettes sitting in apartment complexes. It was maybe a florida thing
Not as cool as 39 4 door making 20. Also is a appreciating asset. Not like they are making new ones.
Old 03-11-2022, 11:30 AM   #35
Darrell S
Darrell S's Avatar
https___bucketeer-e05bbc84-baa3-437e-9518-adb32be77984.s3.amazonaws.com_public_images_8f0ace5b-5.jpg
Darrell S is offline   Reply With Quote
Old 03-11-2022, 03:14 PM   #36
hotrodcbx
Karl
It's a lot more than $5.00 per Imperial gallon!! It's about $2.00/ltr Can.
There are about 4.5 ltrs in a Imp. gallon so that's about $9.00 gallon. Our dillusional PM has brought in carbon taxes and fuel conservation taxes (actually a second carbon tax) and it goes up yearly. Consider we have huge oil reserves and supply the US with 50% of their oil we get no breaks in Canada. I am in Florida untill the snow melts. The gas prices here today are about $4.00 a US gallon (about 3.9 litres). The worst is heating our homes with natural gas which is 80% of all households. These taxes are applied to this as well.
hotrodcbx is offline   Reply With Quote
Old 03-11-2022, 04:03 PM   #37
aussie merc
aussie merc's Avatar
aus not much better $2.00 aud a litre roughly $10 us a gallon THANKS VLAD
aussie merc is offline   Reply With Quote
Old 03-11-2022, 11:08 PM   #38
Lawrie
Lawrie's Avatar
2.24 in Quilpie this morning
Old 03-11-2022, 11:16 PM   #39
Pete
Might be a good time to dig those Fish carbs out of the junk boxes.....lol
Old 03-11-2022, 11:23 PM   #40
Ol' Ron
Ol' Ron's Avatar
Fish carbs???? Pete, that dates you, I had one once!!!!!
Gramps
