03-05-2022, 09:33 AM | #21 |
Re: How common is it to just take the shocks off?
The Model A ride is poor and without shocks it's terrible. Put modern telescoping shocks on it if originals are unobtainable.
Bob Bidonde |
03-06-2022, 08:05 AM | #22 | |
our next Model A is out there in the unknown...... |
03-06-2022, 04:41 PM | #23 |
Thank you for all the replies, it’s nice to know there are several options. Does anyone re-arch the original springs like it talks about in the manual I have and rebuild the existing pack?
03-07-2022, 10:33 AM | #24 |
A person that has a good press can re-arch springs but they should find a good procedure to perform the task and have a proper arch profiles drawn on a large piece of cardboard so that each the leaf can be re-shaped to its intended profile.
Keep in mind that fatigue is what causes them to lose there original profile so re-arching one will leave it more susceptible to cracking in the future. Time and extended use takes it's toll on everything eventually. |
03-07-2022, 11:30 PM | #25 |
Who makes the best bolt on modern shock kit for the rear? The back of my RPU is so light that I'm afraid that I won't be able to get shocks that are not too stiff.
03-08-2022, 07:10 AM | #26 |
03-08-2022, 03:13 PM | #27 |
Can you post a picture of the rear shocks mounted. What shock arms did you use?
Thanks |
03-08-2022, 03:25 PM | #28 |
Give John Holland a call. He rebuilds excellent shocks and is very reasonable.
Shock rebuilder: John Holland 330-483-3896 7208 West Law Rd. Valley City, OH 44280 |
03-08-2022, 09:59 PM | #29 |
I just ordered a pair of friction shocks from Speedway (the friction disc is replaceable) I would really appreciate some pictures of your installation Colonial, I'm having a little difficulty visualizing the install. Thanks!
03-08-2022, 10:25 PM | #30 | |
03-08-2022, 10:46 PM | #31 |
1929 Phaeton bought with no shocks, found some old ones managed to get them apart got them working about 50/50 put them on car the difference was great goes over bumps, etc quite well now.
03-09-2022, 05:21 AM | #32 |
I purchased a set of modern telescopic shocks from Snyders for my 28 ute (pickup) and was most disappointed in the ride. I removed them and whilst the ride was still rough it was just slightly better. On my 28 tourer (phaeton) I ride on MGB shocks, that’s a British sports car and they are good.
The biggest load I’ll carry in my ute will be a couple of small kids. I’d like to remove some leaves from the rear spring. I have seen an article on what to remove and what to retain. Whilst I don’t have it at present I’d like to go further because it will never carry a load. Does any reader have a suggestion. Thankyou (in anticipation), gary.
I know many things, But I don't know everything, Sometimes I forget things. And there are times when I have a long memory. |
03-09-2022, 08:44 AM | #33 |
My car came with only 2 frozon shocks. I just about bought the tube shocks, but I went with the original style for 2 reasons.
1) My car looks pretty close to stock, so I wanted to keep it that way. 2) Most Importantly, ... I didn't want to be the guy who drilled holes into an unmolested frame. I'm funny that way. YES, at the time in 2017, tube shocks were $400 for the set and the originals were $1200. Do I regret the decision? Not a chance, I'm glad I did it, and would gladly do it all over again. Regards Bill |
03-09-2022, 11:21 AM | #34 | |
Enjoy. |
03-10-2022, 07:12 AM | #35 | |
PHP Code:
I made 2 spacers 2" long and 1 5/8" long from heavy wall tubing for each side. Used grade 8 bolts and bent a slight bend in the arm to be sure the nut cleared the body. Very happy so far. Reviews on speedway are pretty good. Hope this helps. Last edited by Colonial coupe; 03-10-2022 at 07:33 AM. |
03-10-2022, 09:26 AM | #36 |
None of the four Model As I’ve owned had shocks on them when I bought the cars, suggesting many A owners did remove the shocks when they either froze up or just stopped working.
Good working shocks make a significant difference in the stability and smoothness of the ride. I have original shocks - rebuilt by John Holland - on both of my cars and am very happy with them. Good Luck - Jim |
03-10-2022, 04:49 PM | #37 |
A while back I purchased a set of 4 shocks from Brattons.
03-10-2022, 08:05 PM | #38 |
I have heard the gas charged shocks are terrible too.
03-11-2022, 06:15 AM | #39 |
Shocks work by trying to force oil via a piston/(vane in the case of a Model A) thru a small hole. The smaller the hole the stiffer they are. It is like trying to force sand thru an hour glass.
https://www.koni.com/en-US/Cars/Tech...ng-Principles/ Gas pressure is added to stop the oil foaming. Foaming causes the shocks to fade as gas can compress. Shock fading is a problem in our outback on poor roads at reasonable speed in hot weather. They can also heat up and burst as they cannot dump heat fast enough. It may be that gas pressure shocks are made harder? For a Model A with lots of friction between the leaves you won't need hard shocks. |
07-19-2022, 02:56 AM | #40 |
My Phaeton didn't have any when I got it used to bounce around a bit so I got some old ones that were ok rebuilt them I think to about 50/50 and it made a great difference to the ride and controllability.
