Old 03-07-2022, 12:00 PM   #1
jeepguy1948
Default Rear Spring Reverse Eye?
I see and hear all the time about "reversing the eye of the spring? Now, I know what it means, and I know what it looks like. What I don't know is can I do this myself (with Mapp gas that's all I have)? I always thought that would ruin the temper. Yes? No?
jeepguy1948 is offline   Reply With Quote
Old 03-07-2022, 01:05 PM   #2
Jim Brierley
Default Re: Rear Spring Reverse Eye?
I don't do that on rear springs, it makes it very difficult to reinstall. I recommend removing leaves to lower the rear of the car. Keep the top leaf in place because it is contoured to fit into the crossmember. Remove every-other leaf. I removed 3 on my tudor, and like the way it sits.
Old 03-07-2022, 01:30 PM   #3
bruceincam
bruceincam's Avatar
You can buy a reverse eye spring ---- ~$250 or so. If you want one, buy one ---- lots easier than making one.
bruceincam is offline   Reply With Quote
Old 03-07-2022, 02:44 PM   #4
Bob C
Here's a link to a video on reversing a Model A rear spring eye.
https://www.youtube.com/watch?v=fx616u1w6sQ
Bob C is online now   Reply With Quote
Old 03-07-2022, 09:51 PM   #5
zzlegend
zzlegend's Avatar
Or you can install it very simply with some square tubing.
zzlegend is offline   Reply With Quote
Old 03-07-2022, 10:28 PM   #6
jeepguy1948
That's a great tip ZZ!
Old 03-07-2022, 10:31 PM   #7
jeepguy1948
As far a $250, well I have had a reverse eye spring on back order for 2 months and have been given no indication as to when to expect it. But then there's the $250 + shipping + tax here in WA, it adds up in a hurry. Mostly it's the back order thing that has me considering any options I might have.
Old 03-08-2022, 06:36 AM   #8
Step-down
Step-down's Avatar
Did you try A Spring
File Type: jpg F09D0859-3F4B-434C-B0C8-3514523BE97E.jpg (30.3 KB, 59 views)
"I can't cry as long as I know the Lord has risen "
Step-down is offline   Reply With Quote
Old 03-08-2022, 06:57 AM   #9
Colonial coupe
Check with Posies in Pennsylvania.
Colonial coupe is offline   Reply With Quote
Old 03-08-2022, 02:06 PM   #10
Chris Haynes
Chris Haynes's Avatar
http://www.posiesrodsandcustoms.com/...-rear-springs/
1921 Runabout
1930 Tudor
Early 1930 AA
Old 03-08-2022, 11:45 PM   #11
jeepguy1948
FYI Posie's is where it's backordered.
Old 03-09-2022, 10:58 AM   #12
Bob C
May be check out these guys, they show a main leaf for $150.
https://www.millworkshotrod.com/prod...ring-1928-1931
Old 03-09-2022, 11:14 AM   #13
katy
katy's Avatar
ZZZlegend, what year is that coupe in your 2nd picture?
Old 03-09-2022, 02:50 PM   #14
Nosetime
Nosetime's Avatar
Millworks for reverse eye.
Nosetime is offline   Reply With Quote
Old 03-09-2022, 06:47 PM   #15
PeteVS
PeteVS's Avatar
Take the main leaf and set on a concrete floor. Take a piece of chalk and trace the curvature on the floor. Now, by whatever means work, recurve that leaf until it matches the curvature but with the eyes on the other side. You don't want to use heat doing this. If you have a spring shop in your neck of the woods, they should be able to do this for you.
Old 03-10-2022, 10:37 PM   #16
larrys40
I would strongly oppose it . There’s really no good reason. A lot harder to use a spring spreader properly ( I saw the clamp idea) . If you want to build a street rod so it. But for a Stock rear and axle I don’t see the point or logic.
And no, you can’t use a map gas torch to do it.
larrys40 is offline   Reply With Quote
