Old 02-26-2022, 08:13 AM   #3
Gene1949
Gene1949's Avatar
Default Re: What's needed to put in a 8BA replacing a 59A
Since you are going to change out the block anyways I would go with the early T-10 4 speed (bolts up to the stock 8ba bell housing) and use an open driveline rear end.
A lot less hassle and far more drivable and reliable.
Gene1949 is offline   Reply With Quote
