Old 02-22-2022, 06:56 PM   #1
CJStefan
Default '49 car spindle castle nut
Anyone have one they want to sell? I was finally putting my front end back together yesterday and somehow one of mine has screwed up threads. Not sure how its possible since they've been sitting in a ziploc bag inside one of the hubcaps but it happened. Contacted Shoebox Central but they said they pulled and sold all they had
CJStefan is offline   Reply With Quote
Old 02-22-2022, 07:32 PM   #2
cas3
Default Re: '49 car spindle castle nut
Are they the same as older fords? I have lots of those
Old 02-22-2022, 08:36 PM   #3
CJStefan
They look exactly the same to me but one of the online places listed what they had up to '48.
Old 02-22-2022, 08:56 PM   #4
cas3
Got a thread pitch gauge ?
Old 02-22-2022, 10:11 PM   #5
petehoovie
petehoovie's Avatar
This is what the correct castle nut looks like....
49-54 Ford Spindle Hub Castle Nut
Old 02-22-2022, 10:42 PM   #6
tubman
tubman's Avatar
From that exact ad : "SORRY - THIS PRODUCT IS NO LONGER AVAILABLE"
Old 02-22-2022, 11:04 PM   #7
CJStefan
That's exactly right. The online vendors show a picture that looks exactly like that but say up to '48 so I'm not sure.
Old 02-22-2022, 11:54 PM   #8
cas3
I have lots of junk here, if you tell what wrench size it is, and the thread count and hole size we can figger it out
Old 02-23-2022, 12:00 AM   #9
CJStefan
I'm pretty sure its 3/4-20.
Old 02-23-2022, 12:03 AM   #10
rich b
rich b's Avatar
Since the book says it uses a 09067 bearing the spindle likely has 3/4-16 threads and the spindle nut used on '36-'48 cars and '48-? F series trucks should work.
Sorry wrong thread pitch, supposed to be 16 not 20; and I knew that.
Old 02-23-2022, 12:18 AM   #11
cas3
From memory, the early ones are tall, and later ones are short with a larger wrench size, like whats pictured. I should have one. Whats the wrench size ?
Old 02-23-2022, 12:21 AM   #12
CJStefan
I cant remember off the top of my head but I'll let you know tomorrow
Old 02-23-2022, 12:37 AM   #13
cas3
A brief search shows me an old tall one, 1 1/8 wrench, and the short one, .590 tall, takes a 1 1/4 wrench, but both are 3/4 16 thread. 3/4 20 is odd, not listed on my tap and die chart on the wall. could be the difference?
Old 02-23-2022, 12:39 AM   #14
deuce lover
deuce lover's Avatar
Bought mine from NAPA yrs ago.
deuce lover is online now   Reply With Quote
Old 02-23-2022, 12:48 AM   #15
cas3
Yes, if it is 3/4 16 NF it should be an easy thing. 3/4 20, not so much
Old 02-23-2022, 01:02 AM   #16
petehoovie
petehoovie's Avatar
Q: Are the large spindle castle nuts all the same?
A: No. There is two different nuts for the early Ford spindles. 1928-35 Have a larger (taller) nut. In 1936, Ford went to a shorter castle nut. All threads are the same (3/4-16) See > Q&A's at https://prewarford.com/blogs/technic...identification
Old 02-23-2022, 01:18 AM   #17
cas3
Good post Pete, now for fun we'll play "can you spot the nuts", like where's waldo. So, yeah, I've been doing some plumbing...I'll clean the bench tomorrow...well, by friday at least. But here's the short and tall, both ford items, both 3/4-16. This is my last post or too many people will be talkin about my nuts. If you find the thread count is correct, send me your address and I'll get it in the mail
Old 02-23-2022, 01:25 AM   #18
petehoovie
petehoovie's Avatar
Old 02-23-2022, 08:01 AM   #19
CJStefan
Those who said 16 thread were correct. I went to the local Ace to try and find a replacement. All they have is 3/4-10 nuts that looked way more coarse than this. I PMed you Cas3. Thanks everybody. Take care
Old 02-23-2022, 11:15 AM   #20
nickthebandit
If all else fails, try McMaster-Carr.
nickthebandit is offline   Reply With Quote
