Old 02-18-2022, 01:16 PM   #1
52 Ford
Default 52 F1 Steering box problem
Have the steering box apart and cleaned. I cant figure out a way to remove the top bearing retainer from the housing. The way it is installed I cannot get a slide hammer to grip the retainer cup to remove.
Any ideas?
52 Ford is offline   Reply With Quote
Old 02-18-2022, 04:11 PM   #2
cas3
Default Re: 52 F1 Steering box problem
If you are talking about the bearing cup, you zap it with a welder, and after it cools it will shrink and fall out
Old 02-18-2022, 05:18 PM   #3
3twinridges
3twinridges's Avatar
You can make a punch out of some steel bar stock with a curved end to catch the lip but it’s a lengthy process to knock it out. I have also used a mig and laid two beads all the way around and you are done once it cools. That is how I remove the front wheel bearing cups as well.
JB
3twinridges is offline   Reply With Quote
