Old 02-09-2022, 04:52 PM   #7
Unclepalmer
Default Re: Model AA cyclinder compression
It woudlnt start so i started changing one thing at a time. The ignition switch had gotten real lucy-goosy when you turned key off it kept running or you could pull the key out so i changed that first. then the coil, then plugs points condenser. then black jumper wire to coil. so now to compression. i so do not want to pull the head.
Unclepalmer is offline   Reply With Quote
