Old 01-31-2022, 04:16 PM   #1
amodel25
amodel25's Avatar
Default Re: Production years for G and H 6 cly flatheads?
The G engine has a crab style distributor on the front of the engine. The H has a conventional distributor on the driver's side.
M engines were installed '49 to '53 in F-6 and larger trucks. My research indicates that they were used in School buses during the same years.
The M engine has a 3.5" bore where the H has a 3.3" bore. Both engines have a 4.4" stroke.
The M has heavier H beam rods, a stronger crank and more support in the bottom end of the block. I haven't tried but I am told that all internal parts between the engines are dimensionally interchangeable except pistons.
amodel25 is offline   Reply With Quote
