Old 01-30-2022, 07:37 PM   #1
1929 Leatherback
Default Cracked valve cover
Good evening everyone.
Removed the valve cover off of my 29, only to find cracks around the area where the bolt is threaded into the cover at the oil return location. The problem is that who ever did previous work on it over tightened that bolt and now it has cracks in it. It's not broke out, but I don't really want to put it back together like that. If it were to breakout while on the road, it would pump the oil out.
My question here is, has anyone had to deal with something like this, or if I could I would buy a new one, but I cant seem to find any new ones
Thanks in advance!!
1929 Leatherback is offline   Reply With Quote
Old 01-30-2022, 07:42 PM   #2
LeonardS
Default Re: Cracked valve cover
Put an ad in the swap meet. There should be plenty of them around. Measure the location of oil return hole, so you get the correct one.
Bert’s in Denver would also have them.
LeonardS is offline   Reply With Quote
Old 01-30-2022, 08:03 PM   #3
Dodge
Used won't be a problem. Its probably one of the easiest pieces of the engine to find.
Dodge is offline   Reply With Quote
Old 01-30-2022, 09:03 PM   #4
tinkirk
tinkirk's Avatar
Thanks in advance!!
I have one if you would like it
tinkirk is offline   Reply With Quote
Old 01-30-2022, 09:36 PM   #5
Gary WA
Gary WA's Avatar
Thanks in advance!!
I have 6 of them but on west coast! Check with your local club! They will be glad to give you one i"m sure!
www.whidbeymodelaclub.com
Old 01-31-2022, 08:32 AM   #6
Bob Bidonde
Bob Bidonde's Avatar
I have seen this a few times:
File Type: jpg Oil Return Pipe Bolt Tightening Caution.jpg (45.2 KB, 116 views)
Bob Bidonde
Old 01-31-2022, 09:23 AM   #7
J and M Machine
Location: 40 Mt.Vickery Rd. Southborough,MA 508-460-0733
Thanks in advance!!
There aren't any new ones available. What you're describing is a common problem as people overtighten the oil return pipe and it cracks the spokes.
We do the crack repair on those covers as finding a crack free one is nearly impossible after 92 years.
http://www.jandm-machine.com/crack_repair.html
J and M Machine is offline   Reply With Quote
Old 01-31-2022, 09:39 AM   #8
31Tudor
31Tudor's Avatar
I don't really think a crack free piece is nearly impossible to find. This piece is readily available and easy to find crack free. Like already pointed out, probably the easiest engine piece to find.
31Tudor is offline   Reply With Quote
Old 01-31-2022, 09:52 AM   #9
TomInCologne
TomInCologne's Avatar
Because every man and his dog buys a full flow oil filter kit and this part is within the kit?
TomInCologne is offline   Reply With Quote
Old 01-31-2022, 10:32 AM   #10
katy
katy's Avatar
Weld or braze it up, put it back on but don't overtighten it.
Old 01-31-2022, 10:45 AM   #11
burner31
burner31's Avatar
I have the same issue, could not find another, put it back on but tightened the bolt just to seal, been four years and no problems, not a drop of leakage.
I'm not going to worry about it at this time.
Keith
Shawnee OK
'31 SW 160-B
Old 01-31-2022, 11:35 AM   #12
Gary WA
Gary WA's Avatar
I agree I have 6 not cracked in the shop!
Old 01-31-2022, 11:44 AM   #13
TomInCologne
no wonder others have none...
Old 01-31-2022, 12:19 PM   #14
Brentwood Bob
Have good ones, but I am out west. Must be the water.
Brentwood Bob is offline   Reply With Quote
Old 02-01-2022, 08:39 PM   #15
1929 Leatherback
Thanks for all the help guys!! At least I know that all hope is not lost!! I do appreciate the help.
Old 02-01-2022, 09:34 PM   #16
old ugly
old ugly's Avatar
there are two styles early and late. make sure you order the correct one or you will need a different drain tube.
if you want new you can get a new aluminum one that has a filter adapter on it.
old ugly
my mom would have told me. "these things are here to test us"
old ugly is offline   Reply With Quote
Old 02-01-2022, 09:39 PM   #17
old ugly
old ugly's Avatar
if you were totally stuck you could probably make an insert that fits into the cover from the back that will accommodate the attaching bolt.
i am sure you will find one,
i have 3 old style ones here i will send you one free . you pay for the shipping cost. probably $25 to ship???
old ugly
