Old 01-30-2022, 05:12 PM   #1
dlfrisch
dlfrisch's Avatar
Default Front Bumper
Can a spring steel bumper bracket be bent? My new left side bracket is bent down/in, where it fastens onto the bumper. Can it be slightly bent to straight it out, without braking the tempered steel ?
dlfrisch is offline   Reply With Quote
Old 01-31-2022, 09:45 AM   #2
31Tudor
31Tudor's Avatar
Default Re: Front Bumper
Yes they can be bent. Usually have to put a lot of heat on them and then bend while really red hot. Since you are putting a lot of heat on it, it is best to do it off the car. I have seen frame horns bent while trying to just bend them on the car without applying heat.
31Tudor is offline   Reply With Quote
