I'm looking for a after market muffler for my 36 pick up. I don't want to pay $350, for a Ford script reproduction. Does anyone know if there is a generic one that will interface with the existing stock exhaust system?
Sent from my LM-V405 using Tapatalk
Thanks Rick McKenney Seattle WA |
#2 | |
![]() Quote:
There are also after-market places that can supply you. Waldron's comes to mind.
Walker made one for my 40 merc. I got it from the Fordbarn wanted site.
You can also search muffler on Rock Auto and pick a muffler by inlet size from 1.65” to 4”
No old time muffler shops in Seattle? Should be easy peasy for them to adapt one for your p/u.
tractor supply~!!!
I used a Walker 18179 on my otherwise stock '36 pickup exhaust system (stock 221 cu in poured bearing motor), went on with minimal fiddling (cut a little bit off the tailpipe side to just leave a straight stub, and cut off a small unused bracket) -cost about $45
Adam
1936 pickup, stock, black 1965 Mustang coupe 289/4bbl, black/red 1971 Alfa Romeo GTV 1750 coupe, dark red/tan 1970 911E 2.2 litre dark blue/black 1968 BMW R50/2 US, black (m'cycle) 1967 Triumph TR6R , sea foam/cream (m'cycle) 2022 Royal Enfield Interceptor 650 red (m'cycle) 1974 Honda CB750 red (m'cycle) 2000 Kawasaki W650 blue/silver (m'cycle) |
Adam. Thanks for the walker part #. I will verify the input and output pipe diameters and order one, if it's correct, otherwise I will make a trip to NAPA.
Rick, This drawing of original muffler might help you.
Don. thank you. This is exactly what I need to talk to the folks at NAPA. Sent from my LM-V405 using Tapatalk
