Old 01-12-2022, 10:27 AM   #1
Leadfoot4U
Leadfoot4U's Avatar
Default Knowing left from right??
I'm running into this with reproduced parts and wondering if others have found this to be true.......overseas manufacturers don't know their left from their right?
I've got mechanical brakes on my 34 Ford and have no intention to deviate from them. Finding NOS parts are practically out of the question now, so relying on what's in the market is where we have to go. Doing a complete restoration requires replacing many old/worn out parts. One such part are the rear camshaft levers. In order to replace the right camshaft bushing, my only alternative was to destroy the original lever in removal. I purchased a right side lever from a repudiable online seller and have found the lever fits the left side and not the right. The angle of the brake rod clevis attachment is to the outside of the frame, not toward the cross shaft that's centered within the frame.
I know Model A camshaft levers will fit a 34, so I purchased a pair from a different repudiable online seller and the images show what I got. They too are marked opposite of what they should be. The clevis ends are bent outward, away from the center of the car when matching the marked right lever to the right side of the car.
These parts are sold as Ford Official Licensed Product, but I think Henry knew his left from his right!!
Notice the label "Made in Taiwan"......enough said!
The fact both Model A and 34 levers have this same problem, AND I ran into this same Left means Right issue with the reproduction king pin set I purchased........the left marked king pin fits the right side of the car. It's buyer beware for not only the user, but for the seller as well.
Leadfoot4U is offline   Reply With Quote
Old 01-12-2022, 11:42 AM   #2
DavidG
DavidG's Avatar
Default Re: Knowing left from right??
With respect, what are shown in your photos are not parts original to the rear brakes of a 1934 Ford. The rear arms or levers were B-2235 and B-2236 on '32-'34 passenger car and commercial chassis rear brakes. They only have a slight offset at the clevis end and were pointed downward in their installed positions. The A-2235 and 2236 levers in your photos were originally installed in an upward position. Their 90 degree offset at the clevis end is unique to Model A rear brakes.
Accordingly, the Model A levers shown in your photos are correctly labeled R and L. Whomever advised you that the A levers were usable on '32-'34 rear brakes was mistaken. The manufacturers of the levers in your photos have it right.
Old 01-12-2022, 01:01 PM   #3
Leadfoot4U
Leadfoot4U's Avatar
I stand corrected regarding the Model A camshaft lever positioning. I didn't realize they are positioned upright on the camshaft rather than downward as the 34. Turning them up, the angle of the clevis is correct.
However, the black painted lever in the first couple of images are the reproduced 33/34 camshaft lever for the right side (as marked by the printed RH on the shaft). It has the same angle as the Model A lever. Unless I'm also mistaken regarding the position of the lever for the 34 (which has the lever turned down), the clevis angle is not correct for the brake rod to travel to the center cross shaft. I'm basing my opinion of the lever pointing down for the 33/34 from what was originally on the car and illustrations of the brake parts of a 33/34.
Again, I'm sorry to mislead those Model A owners who know their cars better than I. But I still have an issue with the mismarked reproduced parts for the 33/34 camshaft levers and their reproduced king pin spindle.
Old 01-12-2022, 01:41 PM   #4
DavidG
DavidG's Avatar
Once again, with respect, your black painted lever in your two photos is not either a B-2235 or B-2236 brake lever. As stated above, those two levers do not have a 90 degree bend in the arm at the clevis end. Whomever sold you (or sells) that arm claiming it to be either B-2235 or B-2236 is badly mistaken. May I suggest a cheap reprint copy of the 1933-34 chassis parts catalog for your library?
In the meantime, check out Vince Falter's website, www.fordgarage.com, for accurate photos of both the Model A and '32-'34 rear brake operating levers.
Old 01-12-2022, 02:58 PM   #5
Bob C
Here's a link to Vince's info on the brake levers that David mentioned.
https://www.fordgarage.com/pages/rea...haftlevers.htm
Old 01-12-2022, 10:59 PM   #6
Kurt in NJ
Kurt in NJ's Avatar
on old english cars it can be interesting---inside the car left is sitting in seat---- outside left is standing in front of car looking at it.
Old 01-13-2022, 12:15 AM   #7
40 Deluxe
Seems like the only thing that would wear on a brake lever is the clevis pin hole. Just weld it up and run an end mill through it. (A regular drill bit is likely to wander off center).
Old 01-13-2022, 09:00 AM   #8
Leadfoot4U
Leadfoot4U's Avatar
40 Deluxe, the "domino effect" takes place when the worn part is the camshaft bushing, that requires removing the camshaft lever, that requires removing the camshaft lever pin, that's frozen in place and no amount of heat or pounding gets it to move. The cutting torch winds up being used as a last resort, especial when there's a belief replacement parts are available. Just so happens, those replacement parts are found out later to NOT be correct.
Here's how their sold:
Notice the package label describing the lever 28-34.
My point to this thread is to show replacement parts are not as original, nor are they going to always be correct in their use (left means right). I'm glad you older restorers have had access to NOS parts to fit your projects. I remember as a high school kid walking through local junkyards full of '30 - '60's cars.....but their all gone now. We're having to use what's available, or don't use them at all.
With respect to manuals, below is one of several I have.
No amount of printed materials is going to produce the original correct part. Nor, are they on a shelve waiting to be purchased.
Old 01-13-2022, 09:12 AM   #9
rockfla
rockfla's Avatar
Leadfoot4U
Thank goodness for FordBarn and Especially someone like "DavidG". As you see...his knowledge is beyond valuable AND is not only backed by years and years of research BUT ALSO years and years of "hands on" "eyes on" experience. Information you can take to the bank!!!!
rockfla is online now   Reply With Quote
Old 01-13-2022, 10:14 AM   #10
AnthonyG
AnthonyG's Avatar
Not sure if ‘35 mechanical brakes r the same as ‘34 but if so & u can wait a few months I’ll be removing all the brake components except the pedal assembly on my ‘35 Tudor w 64k original miles & parts are very nice.
Nomad
AnthonyG is offline   Reply With Quote
Old 01-13-2022, 11:36 AM   #11
DavidG
DavidG's Avatar
'35-'36 rear brake operating levers are, unfortunately in this case, not interchangeable with the '32-'34 versions.
Old 01-13-2022, 11:43 AM   #12
DavidG
DavidG's Avatar
Leadfoot4U,
Armed with that catalog, you now know more than Bratton's as to the applicability of their reproduction levers. In fairness, that they are primarily sellers of Model A parts suggests limits on their knowledge of post-Model A parts. Still, that's not an acceptable excuse for mislabeling their parts. When in doubt, they should not guess.
Old 01-14-2022, 09:03 AM   #13
Leadfoot4U
Leadfoot4U's Avatar
Believe me gentlemen, I very much appreciate your replies! This hobby is full of pitfalls and misinformation (or lack of it......unlike Model A restorers that have repair manuals from Les Andrews to follow. No such manual exists for these early '30 Fords). I've got the Andrews manuals because their the most comprehensive repair information there is for a 33/34!? Oh, the Early Ford V8 Club 33/34 Book has pictures, but they don't give you a step by step procedure to repair a thing.
Which leads me to a new topic I'll post one of these days of what I see every time I read one of the Club's monthly magazines regarding Club membership decline. This idea that during judging, a premium restoration has to use original parts in order to rank a "trailer queen" auto higher than a "driver" that's using the kinds of parts that's available today? I mentioned this earlier, for those of you that were able to restore your project with NOS parts, or parts from the long gone junkyards.....well good for you. But, they don't exist today like before. We new members in todays restoration world don't have the luxury of using the correct part, because they just don't exist as before. Tell me where a new swedgeable B-1118 for a 33/34 can be found?? I've been looking for three years now, two Hershey visits, and countless phone calls......crickets! Do they matter to install? Nope, not if their for a "trailer queen". But to a "driver", yes they do.
My point is, Club membership and judging needs to accept the idea there's a difference between museum piece restorations that never see rain, and those that still hit the road. The "drivers" should have premium consideration. For no other reason....that's what the auto was used for in the first place. And, consideration towards the factual knowledge that original parts don't exist in todays restoration world.
Old 01-14-2022, 11:28 AM   #14
rockfla
rockfla's Avatar
Leadfoot4U
Isn't that why the EFV8 club has Concours, Touring & Rouge classes? Doesn't touring fit the bill for what you are saying......Allowing for certain "modern day" parts, adaptions etc etc? IF not, I stand corrected!!!
Old 01-14-2022, 12:22 PM   #15
Kurt in NJ
Kurt in NJ's Avatar
You probably didn't look in every dollar box at Hershey, without specifically looking I pick up several pieces each year.
Sweging doesn't need the holes perfectly aligned,the swedging process swell up the diameter of the pin to fill the differences, this is why they don't drive right out when the head is ground off.
Old 01-14-2022, 01:48 PM   #16
FlatheadTed
FlatheadTed's Avatar
Drill down the rivet about 11/4 "both sides use 1/8 drill then a 1/4 ? then turn the arm to brake of the remainder, pull the arm of and punch out the bit left ,
http://www.flatheadted.com
Flathead Ted brake Floaters ,
Old 01-14-2022, 02:18 PM   #17
1931 flamingo
1931 flamingo's Avatar
You might try Michael at 3rd Gen Automotive.
Paul in CT
Old 01-14-2022, 04:04 PM   #18
itslow
itslow's Avatar
Maybe the English have different terminology, but left/right is always relative to the orientation when seated in a vehicle - even when outside the vehicle.
Mike
Wanted:
- '32-34 Open Cab Pickup (RPU) parts and documents/articles/info
- ARDUN parts
itslow is offline   Reply With Quote
Old 01-15-2022, 08:11 AM   #19
Leadfoot4U
Leadfoot4U's Avatar
Originally Posted by rockfla View Post
Leadfoot4U
You're right, there are those classes. But, that will be the day when a Touring Class gets the same recognition as the Concours class. No "Overall Champion" will ever come out of the Touring Class as long as the ideal auto is considered museum piece built.
And you're right Kurt, there were still plenty of boxes left for me to look through at Hershey. Anyone saying he walked the entire 20 something miles of vender booths isn't being honest!
Thanks FlatheadTed for the procedure of removing a stuck lever pin. I should have gone that way before taking the torch to it. My rookie mistake. By the way, I'm using your brake floating kit I purchased a couple of years ago. Great idea, and I'm looking forward to using them.....one of these days!
Again, thanks everyone.
Old 01-15-2022, 06:40 PM   #20
Kube
Super Moderator
Kube's Avatar
[QUOTE=Leadfoot4U;2095087]You're right, there are those classes. But, that will be the day when a Touring Class gets the same recognition as the Concours class. No "Overall Champion" will ever come out of the Touring Class as long as the ideal auto is considered museum piece built.
There are multiple classes offered so that anyone that desires to show their car, may do so at the level they desire. I don't believe for a moment that one class gets more "respect" than another.
Thankfully, not all folks desire the same thing. If you want to play on the concourse field with what you term "trailer queens", well, step right up - you are more than welcome.
Keep in mind at that level, it can and does get expensive and difficult.
A rule of thumb I was told decades ago: To restore a car to 90% (900 points) costs X amount of time and money. To restore that same car to 100% (1000 points) costs 2X of time and money.
To date, I have restored 17 cars to the level of (minimum) 997 points. Rest assured; the "investment formula" is quite accurate.
Much of the double investment to get to the 1000 points is precisely due to the lack of quality parts as well as the lack of correct parts. Those parts must be acquired, repaired and / or produced.
Just because the parts may be rare is not a reason to change the rules on the concourse.
So, now it appears to be time for you to decide where you want to show your car.
