11-08-2021, 12:32 PM | #1 |
New to The 1926 Ford Model T
Hi,
Just wondering what is the best place to get parts for the Model T, currently looking for rear axle bearings at the wheel end. Thanks James |
11-08-2021, 07:17 PM | #2 |
Re: New to The 1926 Ford Model T
I usually deal with Snyder’s or Lang’s for parts. Snyder’s sells both Model A and Model T parts. Lang’s only sells Model T parts but also has a huge inventory of good used parts
11-08-2021, 07:48 PM | #3 |
Thank You!
I will certainly check them out. James |
11-11-2021, 10:08 PM | #4 |
Chaffins garage as well, also check the "for sale" on the MTFCA web site those are always up for grabs.
11-12-2021, 06:21 PM | #5 |
Am I not remembering correctly, but did Chaffins have some rear axels made and heat treated, including some that could be ordered slightly longer?
I ordered a pair and they have been great with no problems. I was able to obtain some original roller bearings that were well within specs and at the same time, rebuilt the entire rear end with new parts and it took a while to get the tolerances correct by thinning ever so slightly the bronze thrust washers. Steel safety wired as well. Regards, Steve Boothroyd |
11-12-2021, 06:23 PM | #6 |
11-16-2021, 04:47 PM | #7 |
Another parts vender that's awesome thanks guys.
James |
