09-05-2021, 02:50 PM | #1 |
Errratic ammeter issue
On my '26, the Ammeter sometimes shows what I expect, sometimes it shows no real charge or discharge when I expect to see one, like after starting, or when turning the lights on and off. The generator seems to be charging correctly. Is this a known failure mode of the ammeter, to intermittently just not register, or is it an indication of other problems I need to look for? The wiring is all intact and in good condition, battery stays at 6.3V after use. Gage is OEM, car is original 6V, cutout seems to be OK.
I'm assuming this is an intermittent problem with the gage, checking in here to see if I need to look elsewhere before replacing it. |
09-06-2021, 10:42 AM | #2 |
Re: Errratic ammeter issue
The ampere meter is a pretty basic electro-mechanical device. I'm not sure about the T instrument but the model A indicator can be opened up and inspected. The needle should move very easily if shaken a bit. The needle pivots may be getting worn or some dust may be on them from many years of service. If still clean and functional, I'd be looking at an intermittent cut out function. Worn generator brushes can give intermittent problems as well.
09-06-2021, 06:36 PM | #3 |
Thanks. The needle move with just the shaking of the car, I guess I have to go back though the generator, and study up on the T charging system. What is the best replacement cutout available now?
Testing the output of the generator with a digital voltmeter gives me erratic readings at the generator terminal. |
09-06-2021, 07:33 PM | #4 |
Check out funprojects.com, I got the 5055R had great installation instructions and with proper procedure for setting the generator third brush..VERY IMPORTANT
The 5039B is a nice wiring diagram for 26-27 from Langs, good luck and let us know how you resolve yor ammeter issue. |
09-06-2021, 08:18 PM | #5 |
A little googling makes it seem funprojects is no more. Does anyone have the same device under another name?
09-06-2021, 08:35 PM | #6 |
09-06-2021, 08:41 PM | #7 |
Birdhaven took over Fun Projects - seems to be issues with supply & demand on the voltage regulators - next best thing is a NuRex diode cut-out.
09-07-2021, 08:46 AM | #8 |
all I know is my ammeter took a dump and all went dead. I jumped with jump wires
on the meter started right up. The wiring is all perfect so new meter from Langs all is well. |
10-15-2021, 12:18 AM | #9 |
What a test meter and series next to your amp meter and see if it does the same thing
11-10-2021, 02:50 AM | #10 |
I got mine at Fun Projects as well, It has been working fine ever since installation.
Regards, Steve |
11-10-2021, 09:35 AM | #11 |
I have a Fun Projects ammeter in my ’22 roadster and it works great. My ’27 touring uses a smaller ammeter, similar to a Model A one. It is a foreign made repro and I don’t think that it is very accurate.
11-12-2021, 06:01 PM | #12 |
Are the Fun Projects regulator available anywhere?
Regards, Steve Boothroyd |
11-13-2021, 09:17 AM | #13 |
Birdhaven is now using a mixture of its Texas T Parts purchase as a business model and the web-site carries the Texas T Parts name with the Birdhaven name for customer recognition. The Fun Projects web-site and name that they purchased from John Regan has been shut down but they still have the rights to produce the items that John developed.
The IC chip that was used in the regulator was obsoleted by Texas Instruments some time ago. I'm sure it was being produced by some company in China and most folks have likely heard of the problems with getting memory chips from China. If they can't get chips then they can't produce the regulators till they do. If they fall on hard times as a company then it's anyones guess about whether they can survive it or not. |
