I'm planning an upgrade to the Stromberg 97 carb on one of my cars. I'm trying to organize the parts list. The consensus seems to be that a choke is sometimes needed. Snyder's sells a cable choke, for which I would need to get a 97 with the cable choke bracket. But I wondered if the stock choke could be adapted, or if a third option is workable. I'd prefer not to punch more holes in the firewall if I don't have to.
If the requirement is to not punch a hole in the firewall (or run it through the floorboard) you might consider one of the automatic chokes that Ford used in the fifties. Sorry I don't have enough information to be more specific.
Charlie Stephens |
On one of your cars...as in a Model-A?
Yes, sorry, I temporarily have two Model As and it’s gone to my head.
#5 | |
A new hole in the floorboard would be fine. What type of choke would I use for that? |
Frank |
Yes, you'll need a choke. I've never seen a 97 without a choke. It can be manual or coil spring heat coil addition, your choice.
Best choke? Both hands, from the rear. That'd be the "best".
My Weber has a choke operated by a cable. The knob end is mounted where the GAV/choke rod knob would normally be and the cable goes through the hole in the firewall where the rod would normally go. It is quite natural for me to reach for the cable end to choke the engine when cold as that is where I used to grab the rod to choke the Zenith. The Weber has offset choke plates with a spring connection so that once the engine starts the choke opens up a bit so that the engine does not flood. It still runs rough until I push in the choke, slowly as it warms up.
#11 | |
#12 | |
There have been a few Barners who didn't use cables: Running a cable through the GAV port is totally fine with me, I just wanted to check whether there was a preferred method I hadn't heard about. |
#13 |
I used the same choke cable assembly as they sell for the Webers. Used an existing hole in the firewall.
Alaskan A's Antique Auto Mushers of Alaska Model A Ford Club of America Model A Restorers Club Antique Automobile Club of America Mullins Owner's Club Last edited by CarlG; 10-12-2021 at 11:05 PM. |
#14 |
I think CarlG is using the hole for the vacuum line for the wipers. That saves drilling a hole, as long as you don't have vacuum wipers.
#15 |
#16 |
I don't have a problem either way. I did add the 1/4" phonelic (sp) riser that Stromberg makes between the manifold and carb.
#17 |
I used this and mounted it on the original choke rod mount on gas tank and ran cable thru the original choke rod hole, then attached to a Charlie Price choke bracket
#18 |
Ruth, All Fords that originally had 97's used a solid rod directly thru the firewall. I run a speedster with 3 Stromberg's but only choke the center carb. I took an original rod, cut off near the carb, drilled a hole length-wise in the rod, brazed a 8-32 nut on the side that clamped the cable to that fitting. In the speedster it is a straight line from the "knob" to the carb, I just use a length of brazing rod, not an actual cable. Works fine!
#19 |
My build goal is to imitate a Model A that might have existed in 1936, where the owner has been tweaking it with aftermarket parts and parts from later Fords. A generator, cable choke and distributor from a Model B, the carb from a Model 48 or 78, a Winfield head, etc. So I think the cable approach will be fine.
#20 | |
Probably would have been better if I didn't respond at all. ![]()
