09-26-2021, 08:56 AM | #1 |
Valves
Some of my exhaust valves are running .012 do you think that is close enough or shouldI have the valve stems ground down. If I need to what kind of grinder can I buy to do that
09-26-2021, 09:10 AM | #2 |
Re: Valves
.010" on intakes isn't too bad, could stand to be a bit looser though.
.20" on the exhaust is crazy loose ! Grinding the stems won't help. There is something drastically wrong like bad camshaft, bad lifters. Unless .20" is just a misprint. Grinding the stem loosens things more. I'm assuming the lifters are original style. Last edited by Patrick L.; 09-26-2021 at 10:13 AM. |
09-26-2021, 11:07 AM | #3 |
Re: Valves
.010" on the intakes is a bit tight but won't cause any damage because they run cooler than exhausts.
09-26-2021, 01:06 PM | #4 |
Re: Valves
For Driver: i: .010 e: .015
