Working on a rear brake assembly things were going to smooth . I put the E-brake return spring on the wrong lever I had 4 springs two silver and two black .
Dennis in Kelsey ca |
Dennis, did you use the notched 2 screwdrivers to install the spring - see picture attached. They make the job much easier.
Rusty Nelson |
Thanks Rusty maybe I'll make a couple to get it off .
![]() Dennis Pereira working on a rear brake assembly |
![]() Notched Screw Driver - wrndln |
I agree that's the way I'm doing it also but my body is off the frame .
