Old 09-23-2021, 05:35 PM   #1
oldskool
oldskool's Avatar
Default Re: '40 Ford LED Tail Lights
i called ledlight today and told the genteman my led bulbs were not working ,he informed me i would need a load equlizer for each bulb there are an adtional 2.50ea and installed in the wire leading to the bulb and they get hot besides ,its getting more complacated so im sending my led bulbs back for a refund , so if your led bulbs dont work you will need there load equilzer X2..me im buying 6v bright incondesent bulb 50/14 cp @.80 cents each
oldskool is offline   Reply With Quote
Old 09-23-2021, 06:08 PM   #2
Anteek29
Anteek29's Avatar
Originally Posted by oldskool View Post
i called ledlight today and told the genteman my led bulbs were not working ,he informed me i would need a load equlizer for each bulb.
Hmmm...does not compute. I don't see where adding series resistance would work. The LEDs that I got are super bright when tested directly at the 6 volt battery on my '41 but are dim when installed in the brake light socket.
Have not tried running a direct wire ground back to the tail/brake light housing yet but I anticipate that would be a solution for max lumens. The other thought I had is perhaps the hydraulic brake switch has high resistance.
Alan
1929 Special Coupe
1941 Pick-Up
1955 Victoria
Anteek29 is offline   Reply With Quote
Old 09-23-2021, 06:29 PM   #3
Merc Cruzer
Merc Cruzer's Avatar
Not sure if your taillight lenses are glass or plastic. The 50/14 cp could be a bit too warm a plastic lens, if they are on for an extend period of time. That having been said, that is what I used before I got the LED's
ledlight's response, is very interesting, since I bought my led bulbs from them and they work perfectly, without any "load equalizers"!
Merc Cruzer is offline   Reply With Quote
