Hi gang. Thought I would start our annual spot locater for barn members at Hershey. My crew and I will be in spots RCK 14-21 with V8 parts, included but not limited to wire harnesses, wheel toys, body parts, engine and chassis parts. Stop in and say hello. Pete/Ct.
Tim Ayers & Scott Shepherd OBG 23-25.
Flathead related parts and other junk that I don't need, but you absolutely need in your garage. '39 original radiators '36 roadster fenders Last edited by Tim Ayers; 09-23-2021 at 06:32 AM. |
Don Rogers CCN 59-61 Lots of 35-36 Ford Parts
Obj 15-17. Still sorting thru stuff.
Chocolate Field South CO 19-20. '36 left front fender, '35-'36 cabriolet driver's door, set of mint '36 spiders.
Overhead valve heads for the Ford V-8 sixty block specially imported. Plus possibly lots more. Oh yea and lots of bench racing the wonders of 200 MPH Ford flatheads. ![]()
I use the F word a lot no not that word these words Flathead , Focus and Finish. "Life Member of the Bonneville 200 MPH Club using a Ford Flathead block" Owner , Builder, Driver of the First Ford Flathead bodied roadster to run 200 MPH Record July 13, 2018 LTA timing association 200.921 in one and a half miles burning gasoline. First ever gas burning Ford flathead powered roadster to run 200 MPH at Bonneville Salt Flats setting the record August 7th 2021 at 205.744 MPH |
CU 36-39 with glenn Sanders. V8 truck parts
“The technique of infamy is to start two lies at once and get people arguing heatedly over which is true.” ~ Ezra Pound |
I'll have my '35 fordor parked in RCA 102, but will be walking around looking for goodies most of the time, from Tuesday to Friday. Will also be at the Early Ford V-8 Club table @ Dennis Carpenter's around noon on Thursday.
CJ 80-83 , not too sure what I'll have yet. Possibly a few speed parts.... I'll probably be out walking most of the time though.
-WANTED-
Pre-War Speed Equipment Davies or Morrison Intake Manifold 77-6050B, 81AS - 81SB - 99AS - 99SB 19AS cylinder heads |
I will be there Tuesday thru Friday in the Orange field OBF 12-13 but I am I’ll be vending at either OAG 1-3 (just on the corner of Tim Ayers row) or just across the aisle from him. If stuff does not sell at Carlisle, I will have a really nice 40 standard dash complete with ash trays, radio block off, glove box door, center grille, and a nice gauge cluster, extra ashtrays, and other misc old stuff. My buddies will also have quite a bit of old stuff, depending on how well Carlisle goes.
Hopefully it still happens
#13 |
Hey Men, it is HERSHEY 2021 indeed !!!
RED Field, RCC 74 - 76, Mountain of Ford Parts, 1939 - 1970s.... Lots of O E M FOMOCO and Motorcraft.... Three (3) last N.O.S. FOMOCO / Motorcraft 1964 - 1966 Ford Mustang Head Lite Switches !!! (In the year 2021 !!! How lucky can you get ?!?!?!) Stop on by, Yours, Craig... ( I L 78 - 80 @ Fall Carlisle ) Last edited by mobileparts; 09-23-2021 at 04:30 PM. Reason: Add on |
#14 |
Under light pole 45 in the Chocolate Field. I don't even know my space numbers. Easiest way to let folks know where I am. Lots of early Ford stuff.
#15 |
Gil, I sent you a Fordbarn PM message on a set of these pickup truck headlight buckets, but never heard back from you.
#16 |
I'm at CJ 71-73 Mostly model A stuff. Will be out shopping for 40 parts.
#17 |
I'll be in the orange field OBE 37-38
#18 |
Be sure to visit the Early Ford V8 Foundation site near Dennis Carpenter!
#19 |
I'm at C4J-36
Old signs and stuff! 32 rear spring, 17" wheel, 16" bent spoke wheel,etc. Stop by and sit awhile.
A man should do what he thinks best! "The Duke" Last edited by ct1932ford; 09-28-2021 at 07:41 AM. |
#20 |
my name is george, I will be with Ed (two speed) Carr in spot C2I-49-50 ect. I will have some V8 ford (1937) parts among others. I have a hood for the 37 that in my opinion is the nicest 37 hood out there for sale. If you or anyone you know needs this hood you need to come by and check it out. Never been mounted, painted inside & out, all steel, not a repop. Was going to louver it, but it's just to nice. Should go on a concourse car. I have used hinges & hood prop that go with it. Come by and tell me what you think of at. Always willing to listen & learn from other in the know Ford people.Good luck, see in two weeks.
