Hello to all in T land
I acquired a 1918 T Roadster awhile back, though it has electric start added and changed to a steel firewall. It was running pretty rough and I started down the road of troubleshooting. In the process, I took all the spark plugs out and performed a compression test. 40 PSIG on all four holes. I'm doing this at 7000' elevation so if you add 25% compensating for altitude, round numbers, it would be 50 PSI at sea level I am thinking that is in the ballpark of acceptable for a T engine. Agree or disagree....?? I've got it running well, it's remarkable what rebuilding and timing coils will do in conjunction with a new timer! Thanks |
Your engine seems ok.
I was thinking so,
Thank you for the confirmation |
Even at sea level, 40 would be ok.
I know the voices aren't real but damn they have some good ideas! ![]() |
Hello there Mr Red or Green,
Is it the car or your drive way? Its a great little car! Cheers, gb |
