Old 08-15-2021, 11:09 AM   #1
MyTwOfOrDs
Default 20 inch rims
I got 20" duals on 46 3 ton. Can 8.25 tire go on where 7.5 was? I assume its just a width diff. 6" rim. Are these able to balance?
MyTwOfOrDs is offline   Reply With Quote
Old 08-15-2021, 11:29 AM   #2
alanwoodieman
Default Re: 20 inch rims
8.25 will fit, you will actually go faster! also your speedometer will be off just little
Old 08-15-2021, 02:14 PM   #3
MyTwOfOrDs
I find getting these balanced a real bugger
Old 08-15-2021, 02:17 PM   #4
Bob C
The 1941-48 Service Bulletins shows 7.50 and 8.25 on 7" rims.
Old 08-15-2021, 04:48 PM   #5
mercman from oz
mercman from oz's Avatar
That is one very neat old 1941 Ford Truck with Patina.
Old 08-15-2021, 08:42 PM   #6
MyTwOfOrDs
My 7.5s are on 6's
Old 08-15-2021, 09:26 PM   #7
GB SISSON
GB SISSON's Avatar
The '47 two ton had wider rims so I went to 8.25s. The '37 ton and a half is on 7.50 x 20s. I'm a tire guy, I vote for the 8.25s. The extra circumference is a big plus on modern roads
Old 08-15-2021, 09:30 PM   #8
GB SISSON
GB SISSON's Avatar
And I just found another pic of the '47. I love the 8.25s
Old 08-15-2021, 09:31 PM   #9
Newc
Newc's Avatar
Watch out for sidewall rubbing on your duals with larger tires. Some stock rims do not have the spacing for the wider widths. Newc
Old 08-16-2021, 01:26 AM   #10
cas3
good advise ^^^^, can not let the sidewalls touch, makes heat, go boom. I just retired from a construction company, 5 axle dump trucks, semi's to haul equipment, never balanced any truck tires. seems wrong to me, but 30 years of drivin them...I guess it works
Old 08-16-2021, 08:11 PM   #11
truckdog62563
truckdog62563's Avatar
Before giving an answer to this question, we need to know how the 6” width measurement is determined. Are you measuring across the rim lips, or down inside between rim lips. It matters. The National Wheel and Rim Association (NWRA) measurement standard used during the 1930s, and carried on by Ford in the Green Bible, was to measure across rim lips. In the 1940s the NWRA changed their standards to record measurements down inside across the inner base rim. Thus an early 6” rim is today called a 4.33” rim, and an old 7” rim is today a 5.00” rim. The Green Bible is the only reference I have that cites an 8.25-20” tire as appropriate for what is a current 5.00” rim. Most references cite it for a current 6.00” or wider rim. Never on a 4.33” rim. Stu
Stu McMillan
Marmon-Herringtons
truckdog62563 is offline   Reply With Quote
Old 08-16-2021, 09:30 PM   #12
1952henry
1952henry's Avatar
I would follow the road Stu has paved for you. He knows this subject like no other.
I dig coal, which provides motivation for EVs.
1952henry is offline   Reply With Quote
Old 08-16-2021, 09:55 PM   #13
Bob C
The size I gave in post #4 are the old numbers. The Service Bulletins shows
tire size 8.25x20 wheel size 5.00-S (20x7) .
Old 08-17-2021, 02:25 AM   #14
truckdog62563
Yes, Ford was consistent with itself on the use of an 8.25-20” tire on an old 7” (new 5.00”) rim width. Just inconsistent with the industry as a whole. Given that the member’s truck is a 1941 there is a good chance he has 4.33” wide rims that no reference says should accept the 8.25-20” tire size. Add to this the above mentioned concern about shallow wheel offsets and the risks of rubbing on the dual rears.
Thanks Owen. Stu
Stu McMillan
Marmon-Herringtons
Old 08-17-2021, 09:26 AM   #15
51504bat
51504bat's Avatar
A '40 1 1/2 ton I used to have had 8.25's on the front and they rubbed the fenders when turning. Replaced them with 19.5's before I sold it.
