Old 07-25-2021, 08:23 PM   #1
Y-Blockhead
Y-Blockhead's Avatar
Default Snap-On Dwell Tach
I was given a Snap-On Dwell Tach Model # MT-715 the other day. I was wondering if anyone knows where I can find instructions for it. I Googled it with no love.
Connecting it is pretty straight forward, I am just wondering about the knob on the far right, specifically the "Set" setting? It doesn't have any hard detents, more like a potentiometer. Thanks.
I'm told the dwell angle for a Model A distributor is 42°.
Old 07-25-2021, 09:09 PM   #2
Kurt in NJ
Kurt in NJ's Avatar
Default Re: Snap-On Dwell Tach
When center knob is at "set" adjust right "set" knob so meter needle is in the "set" area on the right side of scale
Old 07-25-2021, 09:35 PM   #3
GRutter
GRutter's Avatar
Call Snap-On customer service at 800-424-7226 or email them. Give them the model number of the meter you have, and they will send you a pdf of the manual.
That's what I did (a couple of years ago) for my MT414 and there customer service was top notch.
GRutter is offline   Reply With Quote
Old 07-25-2021, 09:36 PM   #4
GRutter
GRutter's Avatar
There is a battery inside. Open it up and be sure that there isn't any corrosion
Old 07-25-2021, 09:36 PM   #5
Herb Concord Ca
A few comments. From the picture, the needle zero is off to the right of zero. To adjust first take a damp cloth or paper towel and wipe the plastic meter movement cover. Leave damp, this reduces static charge on plastic cover, then with a small blade screwdriver turn the plastic slot near the center bottom of plastic case to zero meter pointer. As it has a set pot that Kurt mentions, there may be a battery inside the unit. Turn unit over and see if it mentions an internal battery. Enjoy the dwell tach meter.
Herb Concord Ca is offline   Reply With Quote
Old 07-25-2021, 11:56 PM   #6
Y-Blockhead
Kurt, Thanks. That makes Sense. I will do that in the morning. After "setting it" do I turn the pointer to the proper voltage for my car?
GRutter. Yes, I opened it up. I replaced the three "C" cell batteries. I cleaned the minimal corrosion.
Herb, excellent. I wiped off the lens earlier and I think I caused the static electricity! I did try to adjust the meter. I'll try with a damp cloth as you suggest.
Thank you all for your responses. It seems like it is in pretty good shape. The wires have a few cracks in them, I may replace them.
Old 07-26-2021, 01:45 PM   #7
Rob Doe
But what is the correct dwell for the 'A', guys? I thought I heard Les Andrews say in a YouTube video that 31 degrees was right for a 4 cylinder engine???? A curious mind wants to know the correct number. LOL
"It ain't what you know for certain that gets ya in trouble. It's what ya know for certain that just ain't so!"
Rob Doe is offline   Reply With Quote
Old 07-26-2021, 03:56 PM   #8
Ruth
Rob, in post #1 the dwell angle was said to be 42°. When checked, 42° equals .020" point gap. 30-35° would be for a six.
Ruth
Old 07-26-2021, 11:00 PM   #9
KR500
KR500's Avatar
No change should be done to the gauge by adjusting the screw slot on front of meter. When new batteries are installed and meter is set to "Adjust" turn the dial till it matches the set line on front of meter. As the batteries age the set line may need to be adjusted since the batteries don't deliver the needed current.
KR500 is offline   Reply With Quote
Old 07-27-2021, 12:02 AM   #10
Y-Blockhead
Thanks, KR500. I didn't have to adjust screw in front of the meter. The needle retured to zero by itself.
I put new batteries in and adjusted to the Set Line. What is confusing is what are the 6v, 12v and 24v positions for?
Since my car is 12v, do I turn the dial to 12v when the middle knob is in the dwell or tach positions? Thanks
Old 09-23-2021, 12:58 PM   #11
Merc Cruzer
Merc Cruzer's Avatar
I just called Snap-On customer service and no luck and couldn't get past the automation.
I am looking for the manual, for a Snap-On folding primary Dwell Meter MT416.
Thank you,
Merc Cruzer
[email protected]
Merc Cruzer is offline   Reply With Quote
Old 09-24-2021, 04:36 PM   #12
sphanna
sphanna's Avatar
I think the 31 dwell is for the original A. And the 42 is for the B cam which is what all the venders sell now.
Steve Hanna, Polk City, IA
sphanna is offline   Reply With Quote
Old 09-24-2021, 04:45 PM   #13
mercman from oz
mercman from oz's Avatar
Manual wanted, for a Snap-On folding primary Dwell Meter MT416.
Merc Cruzer
mercman from oz is online now   Reply With Quote
Old 09-25-2021, 12:34 PM   #14
katy
katy's Avatar
Looks self explanatory to me. Decide which RPM range desired, then select 4,6 or 8 cylinder engine. Bob's your uncle.
Old 09-25-2021, 06:26 PM   #15
Merc Cruzer
Found one on e-bay for $35, to include shipping. Got it today, you are correct, is it pretty much self explanatory.
I replaced a few bad wires, then removed the works, and sanded the case and primed it. Will repaint it tomorrow.
The first thing I did was the 9 volt battery test, to confirm it worked. Great idea!
Old 09-27-2021, 01:08 PM   #16
hardtimes
hardtimes's Avatar
I use Mallory(bullet proof) dists.
One of my units has an alum ID tag riveted
to unit. This tag,unfortunately …. is not
present on all my units (anyone know why ?).
This tag info:
POINT SET AT… 0.021;
DWELL SET AT…0.034.
Your choice what you do with your equipment.
BTW… your friend gave you a GOOD piece of equip !!
I have one , nearly 60 yrs. bot new !!
Last edited by hardtimes; 09-27-2021 at 09:12 PM. Reason: Xxxx. CORRECTION .017 ; should be.021
Old 09-27-2021, 03:51 PM   #17
jack99
The 715 is a great tool. I had one for years but an undetected leaky battery pretty much ruined it. Take care of yours.
jack99 is offline   Reply With Quote
Old 09-28-2021, 12:00 PM   #18
katy
katy's Avatar
I have one like this: https://www.ebay.ca/itm/203496073248...SABEgL5E_D_BwE
Works good and doesn't use a battery.
