07-13-2021, 02:14 PM | #1 |
best way to get heads off
Hi all,
What is the best way/tool to get a set of heads off? The bolts all came out nice and easily, most were all coated with oil but two center bolts came out with what appears to be water droplets on them. I looked in the manual and I don't have the special tool that they show. Do I need a special head puller? Thanks, Mike
07-13-2021, 02:38 PM | #2 |
Re: best way to get heads off
Been too long since I worked on a Y block but there is usually a spot you can stick a screwdriver and should just pop off.
07-13-2021, 05:54 PM | #3 |
if they havent used sealer on the gaskets they come of easy.
07-13-2021, 06:05 PM | #4 |
07-13-2021, 06:40 PM | #5 |
The heads have never been off the engine, so they are just plain hard to remove I think. Dominic, thanks for the pic I will give that spot a try tomorrow.
Mike
07-13-2021, 06:51 PM | #6 |
07-13-2021, 07:38 PM | #7 |
Yeah, I was thinking the intake ports as well-gently of course.
Mike
07-13-2021, 09:27 PM | #8 |
There you go, no possible damage to the mating surfaces. Just steer clear of valves.
***** - BILLBOARD FOR SALE - LEASE - RENT - OPTION TO BUY - - NO SOLICITING - (Unless A Cheap And Tawdry Bar Maiden ... ) - NO TRESPASS - FISHING - HUNTING - - NO NOTHING - - POST NO BILLS - ... Kilroy was here ... ... sigh ... |
07-13-2021, 10:18 PM | #9 |
If you're talking about a Y-block, notice that there is a little portion at the bottom of the head that protrudes from the engine block at the front.
I have always taken a large, regular screwdriver and stuck it under that little lip there, then tapped the bottom of the screwdriver with a hammer. That will cause it to pop up a little bit. Another way to do it is to have two 1/2" diameter steel rods, each about a foot long. One end of each rod should be beveled round at one end. Stick the beveled end of one rod in the second or third exhaust port and stick the beveled end of the other rod at the opposite end intake port. (Back that one out as needed to keep away from valve stem). Grab the two rods and pull up and the head should break free (after all the bolts are out, of course). I've done it both ways. Always worked for me. |
07-14-2021, 03:02 PM | #10 |
Well they are off! Used a block of wood and some tire irons and they popped right off easily, after a few good whacks. And this is what I found.
GOOD-Some carbon ridge-albeit not all of the way around and just a very slight wear ridge. No major scoring, although there is one spot that can be seen and just barely felt. Standard bore, clean piston tops-more or less and Ford valves in the heads. Not bad for a sub 50K engine. BAD-some sludge, not much and it will get cleaned out when on the stand. some scale and goop in the antifreeze in the water jackets. Rust on some valve heads but I think that is from sitting in the yard. Overall, she is in pretty good shape. Next up is to see what the bearing look like. What do you all think? Passenger head/block and then driver side head/block and finally #6 before scraping and after. Mike
07-14-2021, 05:06 PM | #11 |
Those appear to be 471 heads, which were used on '59 292's. They have the big valves like the '57 ECZ-G heads but larger combustion chamber, so about one number lower on the compression ratio.
I think you said the engine came out of a '57, so at least the heads aren't original. All passenger car Y-Blocks in '57 had ECZ-G heads. Sal |
07-14-2021, 06:27 PM | #12 |
Yep, I just found them on the Y block guy site. So now I don't know what to make of the motor. I will check the bearings this weekend. I may just use these heads as is for now and look for the correct heads later.
Mike
07-14-2021, 08:12 PM | #13 |
The extra steam holes drilled in the block between the center cylinders could have been added later, but my bet would be the block is the same vintage as the heads.
07-15-2021, 04:32 AM | #14 |
what are the casting letters on the block.59 blocks are b9ae.they didnt have the steam holes until the the last 2 years 63 and 4.unless you have one of these its a rebuilt.
07-15-2021, 08:53 AM | #15 |
07-15-2021, 10:16 AM | #16 | |
Sal |
07-15-2021, 01:22 PM | #17 |
Oh, she's very careful not to leave any marks. She can take a cast iron frying pan and bounce it off the side of my head (sounding similar to church bells) with no resultant lacerations or swelling.
07-15-2021, 01:26 PM | #18 |
So, since this engine has been opened-at least on the top end so far-it has become a Frankenstein motor. Not that that is bad, but just not what I was hoping for. I checked the numbers on the block, heads, exh and intake manifolds and I get different years. This is what I got:
Block= ECZ 6015C=292/312 Exhaust manifolds R=B9AE, L=EDB (58-59 292 manifolds) Water outlet=ECE-8/3 Intake=ECZ-9425-B So my guess is this, the engine is a genuine low mileage 312 (well at least at this point in time) that went to the fairlane I got it out of. But at some point the heads and manifolds got replaced along with the valley pan. The only reason I say this about the pan is that it was designed with a PCV valve in it from the factory. It has a stamped indentation where the valve sits so I don't think it is a later mod. Mike K, the 4100 on this car came with an electric choke? Why? I thought they all were mechanical pulling heat from the manifold. That is preferable as there are fewer possible problems.
07-15-2021, 02:00 PM | #19 |
It's a Ford/Autolite 4100. They came out in 1957. To my knowledge they were all electric choke. These are great carbs, prolly about as close to set it and forget it as it gets. The venturis are annular discharge, good for gas mileage and performance. If you don't want it I would be happy to get it out of your way...
Often wrong but never in doubt. |
07-15-2021, 02:29 PM | #20 | ||
In all actuality, an electric choke is a better performer. Much less maintenance and mechanical problems. Quote:
AUTOLITE and MOTORCRAFT were marketing terms. All had hot air chokes
