hey barners, I have woven brake linings on my 37 fordor that were done not to long before i got the car. I assume it was done that to keep original. i have adjusted all 4 corners a few times,and think i have got them about as good as it gets. did ford use woven because thats all there was in 1937 or was because to make the drums last longer. i was wondering if the bonded brake shoes will fit in my orig backing plates? im sure the bonded linnings will wear the drums but stop a whole lot better is this correct? tom
I wish I knew the answer but I have read the woven provide better braking, which is a good thing.
Do you know where to get the woven? We’re having brake problems on a 38 Tudor (as in almost no brakes). I think 37 & 38 have similar (cable) brakes. |
I have a gut feeling that woven linings provide better stopping with less effort than bonded linings.
19Fordy>>>I have a gut feeling that woven linings provide better stopping with less effort than bonded linings.>>>
I do too. Wovens were recommended for older motorcycles with Lockheed style mechanical brakes for that very reason. I think FlatHeadTed still offers bendix self-energizing conversions (floaters) for lockheed-style mechanical brakes that greatly improves stopping power with even less pedal effort. |
woven lining will stop your car much better .if you use the modern stuff you will be very unhappy
Stay with woven .My '33 didn't stop worth a darn with the new bonded linings.I couldn't even lock them up.I was going to change them out to woven but ended up selling the car and included the woven set .
ThirdGen stocks the woven for 37-38 Fords. Last edited by deuce lover; 07-04-2021 at 07:01 AM. |
as i said check with your supplier as to which lining they supply most will supply a hard lining as standard as it will last longer but requires more pressure to stop [great for power systems not so with manual system] They should be able to provide a softer option .Factory woven linings are soft so work better but dont last as long and dont wear drums anywhere near as fast its all a trade off
thanks everyone that responded to my question about woven brake linings. i never would have thought that woven would be better than a bonded lining. i am keepn them. oh by the the way AKCJ i think you can get the woven lining kit with rivets from macs, CG, first gen, and others. thanks again barners for advice. tom.
I believe floaters are available for 37-38. If so that should be a grea upgrade.
My suggestion is call JG Brake Drum Reline and have him redo your shoes. He has a great shoe material. Great guy to deal with. He also will reline any make drum.
#13 |
Kurt in NJ you are correct about the floaters. the big 1937 ford book says so.
#14 |
My early 38 didn't. Maybe it was an option? Jack E/NJ
